Retard Timing Turbo
Old Jan 25, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Retard Timing Turbo
Ive tried searching but no luck.
So ive read when turboing a car, i HAVE to have the timing retarded or ill blow a piston or something, make a hole in it... Would a Vafc cover that or will i have to get something like an E Manage... What other then e manage is there to offer?
What psi can i run before i retard the timing so i dont hurt anything major in the engine?
Old Jan 25, 2005
civic01vtec's Avatar
as opto has found.......as our cars make the transistion from vac to boost, timing is actually increased.
The only way to fix that is with a the e-manage.
Old Jan 25, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
I actually wanted to know this myself.
Old Jan 25, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
you can use msd ignition to control your ignition timing. You dont have to buy e-manage to control timing. The msd will do it all.
Old Jan 25, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
i use to run boost on my accord, and the afcII advanced my timing, i had to get a msd btm or boost timing master and that took care of it for me, that is if your running the afc hack...if you got emanage itll take care of that for you
Old Jan 25, 2005
HyaBoosta's Avatar
I don't think that msd has come out with a system for the k20 or d17 ignition system. they aren't the same as the B-serise.
Old Jan 25, 2005
MSD doesn't make parts for our type of ignition.
Old Jan 25, 2005
KalliGarri's Avatar
so what can i buy JUST to retard the ignition? i dunt wana buy a full e manage.. i want something cheeper
Old Jan 25, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
I thought you could get something like an AEM cam Gear and manually retard the timing yourself.
Old Jan 25, 2005
that adjust cam timing
cam timing and ignition timing are 2 different things
Old Jan 25, 2005
im stock now! T.T
MSD works for any car as long as they have 12v-16v electrical system. Heres the module you need to buy:
http://msdignition.com/ignition_4_6200.htm
Heres the retard control:
http://msdignition.com/tc_7.htm
Old Jan 25, 2005
Havok2k1's Avatar
Wicked Pissah Admin
civic redline, do you have this MSD hooked up to your D17 right now?
E-manage is the ONLY way (not cams or VAFC).
I hate when incorrect information is spread in here....
Old Jan 25, 2005
C2i0v0i1C's Avatar
SuperMODrizd
and the links u provided look to be a for a distibutor style system, when u look a lil further down there are systems for a distributor less system
Old Jan 25, 2005
like i said there are msd universal boost timing masters which can be applied to internal or external coil
just get emanage, afc+btm costs about the same thing...maybe a little less but its worth it to have the emanage
Old Jan 26, 2005
HyaBoosta's Avatar
i know the ignition can be controlled by the emenage but I am questioning if the coils themselves will hold up and not burn out at that rate of fire.
Old Jan 26, 2005
TheSmuggler's Avatar
^^Get it done right, spend the extra money and feel good because you bought the best thing, emanage =)
Old Jan 26, 2005
im stock now! T.T
no i dont but will in the future.
Old Jan 26, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Good luck with that.
Timing shouldn't just be retarded because you have boost. It's all a matter of properly monitoring the engine and tuning the ignition maps in order to extract the most power in the safest operational range.
Old Jan 26, 2005
im stock now! T.T
sorry I dont have turbo and dont plan too unless I upgrade the internals. My friend with a junkyard turbo uses the msd6 blaster coil on his ignition and start/retard module from msd. He also has rev chip so he can rev to 8.3 redline. I told him not to over rev unless he needs to because over revving chips will blow your engine easily. But then again, this guy can buy a new engine and install it by himself.
Old Jan 26, 2005
I'm talking about you installing a MSD 6BTM on a 2001+ civic. Good luck with that.
Old Jan 26, 2005
im stock now! T.T
not going to be anytime soon, but thanks!
Old Jan 26, 2005
e-manage plus all harnesses and support tool is about $600. Kinda expensive.......but well worth it.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Supramk3
May 11, 2015 07:55 PM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
cloudguy
Apr 28, 2015 05:02 AM
