Doing K20 Swap Need Help!!
Old Jan 23, 2005
DFCivic's Avatar
DFCivic is an unknown quantity at this point
I need help figuring out the wiring. Im doing a k20 swap and i have all the rsx ecu wiring diagrams and the civic ecu diagrams. However, there is one of the rsx connectors that comes from the engine bay along with the A & B connectors. It is the rsx body C101 connector and it is grey with 20 pins and it hooks up to the civics body harness connector(also has 20 pins). The problem is that these wires are a little mixed and need to be matched, and i cannot find the wiring diagram for this connector for the civic in order to match it up with the rsx's. If you can help me i will appreciate it very much. Better yet if someone has the hasport harness and can tell me exactly what was done on it, it'd be great. If so, PM me and we'll work something out. $$
Thanks
dfcivic
Old Jan 23, 2005
nismostreets21's Avatar
nismostreets21 can only hope to improve
rather then tryin to do all that wiring y not buy the hasport wiring harness conversion
Old Jan 23, 2005
DFCivic's Avatar
im thinkin of doing that, but its really only one clip on the harness that has to have the pins rearranged. So unless im stuck, ill hold off on the hasport harness.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
