Would this intercooler piping work?
Old Jan 13, 2005
abmerop18's Avatar
Jam out with your clam out.
it says it is for the 01-04 civic, so i guess it might work unless they just put generic years down. you guys think it will work if i have a charge pipe already? would it be worth $150 for it if it comes with the piping, couplers, and all clamps needed?
Old Jan 13, 2005
dezod's Avatar
7thgen Power Maker
Probably have to relocate winshield washer reservoir and/or loose A/C and/or ABS
edit...also where is the piping from the TB?
Not worth the $$
Old Jan 13, 2005
abmerop18's Avatar
i already plan on ditching the windshield washer reservoir and i do not have ABS, so that is not a problem. i will probally end up just buying the 4 U bends i was talking about earlier and get the couplers and clamps seperate
and i already ahve a charge pipe, so i dont need a pipe that goes to my throttle body.
Old Jan 13, 2005
abmerop18's Avatar
and with a 2.0-2.5" thick intercooler, i shouldnt have any problems with having to loose the AC condensor
Old Jan 13, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
^^I think he may have been talking about the a/c compressor, but then again there wouldnt be a reason to keep the condensor either.
Old Jan 13, 2005
C2i0v0i1C's Avatar
SuperMODrizd
if u loose the ac u loose the condensor, and the compressor, and in that case u might as well take out all the hoses too to unclutter the engine bay, thats what i did
Old Jan 13, 2005
dezod's Avatar
7thgen Power Maker
Exactly. I run a 2.5" core with the condensor. I can even run a 3" core if I wanted to.
Old Jan 13, 2005
abmerop18's Avatar
so would these piping work?
Old Jan 13, 2005
tfnaaf's Avatar
BLDNPSI Mod
im sure it would but would need some fab work to make it fit properly. Back on the winshield washer bottle subject. I've found a universal washer bottle cost me $32. I plan on making custom bracket to mount it in the area of the right strut tower and the cruise control box on the firewall. It's made by Anco if your intersted i can get the part number. Im hoping to start on the piping in the next week or 2 if it goes as planned!
Old Jan 13, 2005
tfnaaf's Avatar
BLDNPSI Mod
BTW is that 2.5" pipes or ???? and it sounds like a decent price for including hoses and clamps. Have you seen the clamps it comes with? Has anyone ever made the intercooler piping them self and had the tubes bead rolled on the ends and if so how much did it cost ya?
CarStuff
Dec 6, 2020 12:52 PM
mrcell24
May 19, 2015 10:02 AM
ORskier
May 3, 2015 12:54 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
colombianDXcivic
Bolt-on Engine Performance
Nov 22, 2001 03:17 PM
