Greddy Turbo Timer *Problem fixed*
Old Jan 11, 2005
abmerop18's Avatar
Jam out with your clam out.
i am having a little trouble trying to get the correct speed in km/h to display on my TT. i downloaded the english instruction from greddy's webpage, but i still cannot figure it out. i did the whole set thing where you do the 40 km/h run and press T to set it, but it didnt work. there are two different set speed things i believe because when you do one, the screen lights up red and the other lights up blue. i tried both. i have the purple wire ran to the pin 18 of connector A on the ECU harness for the speed sensor. the speed just jumps all the *** over when i am in speed mode. does anyone know what to do?
on a side note, here are some pics of the install
Old Jan 11, 2005
abmerop18's Avatar
dammit. now the turbo timer part is acting up on me. i had it workin for a while, then when i started messing with it to try to get the speed workin, the TT wont work now. the car just shuts off. what do you guys have your setting at the "Ig" or "Acc"? also, is there a way i could just reset the whole TT to get it back to factory settings? thanks.
Old Jan 11, 2005
abmerop18's Avatar
well i got the speed and rpm to work on the setting of Ig on the screen and back of the unit, but the problem i have is that the only time the turbo timer function itself works is if i just turn the car on, then turn it off. then the turbo timer will come into play. it isnt working at all if i start going and then turn the car off a couple minutes later. the car will just turn off without any help from the turbo timer. does anyone know what the problem is or what i could so to fix it? i woudl greatly appreciate it. thanks.
Old Jan 12, 2005
abmerop18's Avatar
i dont f'n get it. i checked all of the wiring and it is exactly like it should be. i dont see what the problem could be. i tried everything and it is still doing the same thing of not shutting off right. does anyone know WTF the problem is?
Old Jan 12, 2005
abmerop18's Avatar
ok i think i figured out the problem. the Greddy Turbo timer has a safety function involved with the speed sensor. if it senses that the car is moving, it will shut the car off. well, my problem was i couldnt get the speed sensor to work properly and the TT kept reading it at improper speeds and even when i was going 0 it said the car wasstill going. so i think i solved the problem by disconnecting the purple wire from the speed sensor.
Old Jan 12, 2005
abmerop18's Avatar
not that anyone cares though, since no one is replying to this thread.....
Old Jan 12, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
go get some gas
Old Jan 12, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
looks nice side by side
Old Jan 12, 2005
C2i0v0i1C's Avatar
SuperMODrizd
its fixed i take it
Old Jan 13, 2005
XxJDMCivicxX's Avatar
Is this easy to use I was looking to buy one? Anyone have any other suggestions?
Old Jan 13, 2005
abmerop18's Avatar
very easy to use. the only thing i had trouble understanding was how you switch modes because it kept saying to press P+T or P+S or something liek that and i was doing them at the same time. what you really have to do is hold down the P button and press the T button to change main modes, and the S to change submodes
Old Jan 13, 2005
HyaBoosta's Avatar
does is keep your car on after you drive? I am going to install my hks TT today.
Old Jan 13, 2005
abmerop18's Avatar
yes it does. some thing to remember though are to put it in neutral if you have a 5-speed before you shut off because the car will keep running and if you leave it in gear and take your foot off the clutch, it will stall. also, you cannot lock your car untill it shuts off, so you have to wait for the turbo timer before you can leave your car.
Old Jan 13, 2005
HyaBoosta's Avatar
do you have an aftermarket alarm on your car?
Old Jan 13, 2005
taz757's Avatar
The whole point of a TT, is to allow you to actually get out of your car and lock it and walk away, while the car is still running. Sounds like you have something screwy in your wiring.
Old Jan 13, 2005
abmerop18's Avatar
no
try opening your door with the car running and the key still in there. then try to lock the door like you would if you dont have an alarm by pulling thr handle and pressing the lock button, same thing.
you can lock it from the outside with a key. i dont have keyless entry, so i can lock it this way. i would assume you could do the same with keyless entry.
Old Jan 13, 2005
C2i0v0i1C's Avatar
SuperMODrizd
its something set up by honda so u dont lock the keys in the car, so nothing is screwy at all
Old Jan 13, 2005
abmerop18's Avatar
^ werd
Old Jan 13, 2005
HyaBoosta's Avatar
^ werd
to your mother
Old Mar 22, 2005
TheSmuggler's Avatar
Ok bishes ima bring this back since no one says anytihgn about it. Is there a way to lock your car (I have keyles entry) with the car still running, a la with a TT. Lets explore the options =)
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
Misfit2613
Jul 30, 2015 09:49 AM
