E-manage?
Old Jan 7, 2005
exturbo6's Avatar
E-manage?
If I Invested In This Could I Use My Stock Injectors With The Extra That Came With My Turbo Kti Or Do I Have To Get The Rsx Injectors?
Old Jan 7, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
E-Manage can control extra injectors along with stock.
Old Jan 7, 2005
exturbo6's Avatar
o nice...so you think its worth the money to get this? cause i have a v-afc in my car but the shop i had install it could figure it out so its not hooked up right..could i use that instead of getting the e-manage?
but i read in a past thread that the e-manage was better then the a-afc or s-afc, is this true?
Old Jan 7, 2005
HyaBoosta's Avatar
yeah the emenage is better and hooks up the same way that the VAFC does. It can controll the ignition, bigger injectors,sub injectors,af,ect. But the vtec feature isn't workin on our cars yet. so you have to leave off the vtec wires. Hit up Jeff(streetlevelperformance) Im sure he can get you one for a good price.
Old Jan 7, 2005
exturbo6's Avatar
thank you..ill drop him a line.
Old Jan 7, 2005
exturbo6's Avatar
would my car run better with doing the e-manage?
Old Jan 7, 2005
HyaBoosta's Avatar
what do you have done to your car?or what do you plan on doing?
Old Jan 7, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
thats kinda hard to read.
Extra Injectors that came w/ the kit. I guess you got a TSI kit???
Old Jan 7, 2005
exturbo6's Avatar
as of now i have the tsi turbo kit upgraded turbo with 2 extra injectors. i have a cam gear, pulleys. what do i plan, well just to get a lil more out of it, looking to boost 10psi.
Old Jan 7, 2005
exturbo6's Avatar
yes i have the tsi kit.
Old Jan 7, 2005
bakablo's Avatar
bakablo is an unknown quantity at this point
10 psi is a bit much for what u have done to it.. any engine work/clutch?
Old Jan 7, 2005
exturbo6's Avatar
no engine work, stock internals. im getting a clutch by the end of this month.
Old Jan 7, 2005
HyaBoosta's Avatar
yeah I say def. upgrade to the emenage and try to get the injector,ignition,and pressure sensor for it.
Old Feb 26, 2005
exturbo6's Avatar
ok so i got the e-manage with the injector, ignition harrnesses and i also got the pressure sensor. plus i bought arp head studs. just need to buy a new head gasket.
Old Feb 26, 2005
exturbo6's Avatar
i just wanna know since i have the e-manage with everything, do i need to buy new injectors? or can i use my stock ones with the 2 extras still for my setup? thanks!!!
Old Feb 26, 2005
Havok2k1's Avatar
Wicked Pissah Admin
You can use it either way... Personal preference really, although arguments could be made for either....
Old Mar 17, 2005
exturbo6's Avatar
ok so i have the e-mange in my car. inj, ign, and pressure senor harnesses and senor. just got it back today. So im going to get on it and see how it was after being tuned and dyno'd and it was like i was hitting rev limiter at 3500 rpms. Does anyone know what this could be? Then i go to merge onto the parkway, wanted to see if it would do it again, and i couldnt rev past 3500 rpms in every gear. Could only go 70 mph. Then i gave it a lil gas and it was fine like nohting was wrong. I could go faster then 80mph with no problem.
Old Mar 18, 2005
HyaBoosta's Avatar
Sounds like the map sensor wire might have a bad connection
Old Mar 18, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
yeah, that has to be the map sensor wire...aparently you shop didnt tune it then, cause they would have noticed that it didnt rev above 3500rpm.......
Old Mar 18, 2005
exturbo6's Avatar
well you see i hear what your saying, but the only thing is whent hey were tuning it, it was reving without a problem. i didnt get to see them dyno it but i heard everything. it wasnt cutting out. it seems like it only does it when i go WOT. but idk. im going to go to the shop tommrow and see if they can lokk at it real quick and fix it.
Old Mar 18, 2005
exturbo6's Avatar
sucks too, there are so many cars out on this road, rt 37 int oms river, where everyone goes. and i couldnt even **** with no one. i just get ****ed with and can do anyhting.
Old May 9, 2005
exturbo6's Avatar
ok, so im trying to get my e-manage to work. It at a place right now and they told me that the e-manage is not holding the map settings. they try to get the settings to hold and then they change to default. is the harnesses hooked up wrong? car runs thou keep that in mind. the e-management just doesnt hold the settings. they ordered a new one to see if mine was broken and its not. so they think its the wires that are not connected right? any thoughts ont his. thanks
dezod
Engine Management
112
Feb 7, 2008 12:38 PM
abmerop18
Engine Swaps
Dec 13, 2004 03:10 AM
shady88
Engine Swaps
Jul 30, 2004 02:54 PM
opto_isolator
20
Jul 2, 2004 09:37 AM
