Turbo Install questions
Old Dec 30, 2004
HyaBoosta's Avatar
I had 2 quick questions.
1.What is the best way to remove the 2 studs that hold the fuel rail on so that I can put the longer bolts in for the rsx-s injectors?
2.Can anyone show in a pic which vaccum line is the brake booster line?
thanks a ton in advance.
Old Dec 30, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
To remove the studs you need to use the 'double-nut' technique
put one nut on the studabotu half way, and then another right on top if it...'tighten' both of the nuts into eeach other so they are tight against each other...then loosen the bottom nut...doing this should make the stud begin to loose itself out...
Old Dec 30, 2004
HyaBoosta's Avatar
^thanks for the tip. anyone got any info or pics of the brake booster?
Old Dec 30, 2004
abmerop18's Avatar
Jam out with your clam out.
the brake booster should be the curcular looking thing with a couple vacuum hoses coming out of it. it is right against the firewall behind the throttle body. ill take some pics of it tomorrow.
Old Dec 31, 2004
HyaBoosta's Avatar
^thanks
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
