URGENT ... Need Picture/Description of oil restrictor (feed line to turbo)
Old Oct 22, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Exclamation URGENT ... Need Picture/Description of oil restrictor (feed line to turbo)
Someone please give me the size (diameter) for the oil restrictor that goes in the oil feed line to the turbo. I am using the steel braided line that comes with the SF kit. Car smokin like crazy..
Did the oil restrictor solve the smokin problem for anyone ???
Edit: I got the size (0.065"). Now I need to find or make one of my own. Can someone help me out with this. Pictures? Description? Anything?
Thanks!
Old Oct 22, 2004
deciuss's Avatar
Boosted Auto
is your drain line going down the whole time? if not it will smoke due to exess oil
Old Oct 22, 2004
Ahtasham's Avatar
Yes the drain line is almost vertical and the turbo is located at least 1 foot above the drain point in the pan. However, the drain point in the pan is much lower than where people usually have it.
Old Oct 22, 2004
deciuss's Avatar
Boosted Auto
if you did not get it yet i will try and mesure it once i get to my gfs parents house today if i get some time.
Old Oct 22, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
If your return line fitting is lower than the oil level in the pan, Oil is probably filling up the turbo instead of being drained out of it. I had problems with smoke too. I got a new oil pan and re-attached the fitting so it was at the absolute highest I could get it on the pan and made sure there was a straight drop from the turbo to the pan.
Old Oct 23, 2004
Ahtasham's Avatar
Thanks buddy but yes I got the size, its 0.065 inches. I mailed SF and they replied back in no time. Good Customer Support Hope it stays like that .......
Old Oct 23, 2004
Ahtasham's Avatar
Did raising the drain point solved the problem for you? You also used the oil restrictor, right? Did that help? Lemme know asap .... thanks!
Old Oct 23, 2004
fuchs's Avatar
Yes, I am using a restrictor and I haven't had smoke since I relocated the drain line and fitting
Old Oct 23, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
the hole for the return line should begin no more than 1 inch down from the flat rim of the oil pan..
Old Oct 24, 2004
Ahtasham's Avatar
OK I am getting the relocation done on Monday. Also tyring to make(or find) the oil restrictor .... any ideas ???
Old Oct 26, 2004
Ahtasham's Avatar
Come on guys, someone must be knowing how this thing looks like ... just gimme some description so that I can get started. ?????????
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
RIPSAW
Nov 6, 2015 04:36 AM
PierrePierre
Jun 17, 2015 06:22 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
