NX or Zex
Old Aug 29, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Exclamation NX or Zex
In your opinion, which is better? NX wet kit, or Zex wet kit?? Juice guru's help!
Old Aug 29, 2004
streetglower's Avatar
I have heard that nitrous express is way better.
Old Aug 29, 2004
Boosting Daily
Yeah, i'm leaning towards NX too. The NX kit offers a 35, 50, and 75 shot, while Zex only offers 55, 60, and 75. Being as this would be my first nitrous kit, i would wanna use a small 35 shot to get use to everything. Still though, what are some pro's and con's to each kit?
Old Aug 29, 2004
I am not to familiar with the pros and cons of each, but from reading things about each kit, it seems that nitrous express has more to offer.
Old Aug 30, 2004
HyaBoosta's Avatar
i had an nx kit for about a year. a 50 shot is safe on a stock engine as long as your not stupid with it and try to max out spraying or let it bounce off the rev limiter. but i never had a problem with nx and the kit is very simple to install and easy to adjust.
Old Aug 30, 2004
Boosting Daily
What RPM would you suggest changing gears at while spraying, and what gears would you spray in at the track?
Old Aug 30, 2004
HyaBoosta's Avatar
i would shift at about 6500 rpms. At first you wouldn't want to spray when launching. it takes some practice and you have a higher chance of bouncing the limiter. I would launch hard run 1st gear then as soon as i shift to second i start to spray thru 4th.
Old Aug 30, 2004
Boosting Daily
Exclamation
Does the NX have a floor switch behind the gas pedal or is it like the zex kit and just know when you're at WOT? Would you have ur kit turned on when launching? I mean like would you have it on and just not floor it, or would you have the kit off, and then switch it on after you're in 2nd and WOT? I guess what i'm asking is could i have the main switch to the kit off while launghing in 1st then after switching to 2nd and at WOT flip the master switch on? Could i work it like that, or would that be just wrong all together. Or did you have it on and just not floor it in 1st? Anyways, i gotta work on my shifting, i've missed gears a few times. Def. don't wanna do that with N2O!
Old Aug 30, 2004
Nick's Avatar
Formerly 2blu
Wont the nitrous turn off a few hundred rpm before u hit the limiter anyway. Maby thats just my friends.
Old Aug 30, 2004
HyaBoosta's Avatar
nx doesn't have a floor switch behind the pedal. It's a switch that gets mounted to your throttle body and when you open up the throttle body it pulls back and hits the switch and sprays. IMO i like to keep the arming switch off during lauch. I don;t wanna stay light on the throttle on a launch and bog. I just kept it off then engauged it as soon as I hit 2nd (keep the switch somewhere near your hand so you don;t have to go reaching while running if your gonna do that.).
2BLU:the basic kit will not shut off before the limiter, if your throttle is wide open then it will continue to spray unless you have a window switch that allows you to set exactly what rpm's the system will spray during. you could set it to only spray 3500-6500. thats prob. what your freind has.
Old Aug 30, 2004
JoshLuke's Avatar
JoshLuke is an unknown quantity at this point
what about auto trannies, can u just keep the pedal floored or do u have to let off the gas?
Old Aug 30, 2004
Boosting Daily
I would say just keep it floored cuz an auto tranny changes at around 64-6500 RPMs anyways, but i'm sure you'd have to get like a tranny cooler or something to protect it.
Old Aug 30, 2004
tfnaaf's Avatar
BLDNPSI Mod
when launching dont have it floored with the N2O spraying until the car is in motion or atleast around 3,000 RPM. Any lower RPM with N2) spraying and you will run the risk of a backfire and DISASTER!
Old Aug 30, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
you guys run your nitrous on the street even tho its illegal?
Old Aug 31, 2004
tfnaaf's Avatar
BLDNPSI Mod
No Way, that would be illegal
Old Aug 31, 2004
HyaBoosta's Avatar
I didn;t know it was illegal, I got pulled over a few times and i had the bottle sitting on the back seats(when they were dropped down.) and it was hooked up and a cop has never said anything to me.
Old Aug 31, 2004
ZdS03Civic's Avatar
Its illegal to have it hooked up on the street. You can have the bottle sitting in the back but if it is opened or hooked up...illegal! I'd say you got pretty lucky.
Old Aug 31, 2004
Havok2k1's Avatar
Wicked Pissah Admin
FYI, Some of the NOS kits are 50 state legal....
Old Sep 1, 2004
Boosting Daily
Smile
That's why you keep your Sh*t in the trunk with a remote bottle opener!
Old Sep 1, 2004
ZdS03Civic's Avatar
No **** but its still HOOKED up even when it is closed.
JoeB16
61
Oct 16, 2003 07:58 PM
ViNRoCk8
Feb 24, 2003 11:38 PM
nucks
Jan 27, 2003 06:27 PM
BaNgCiViC2k1
Bolt-on Engine Performance
Jan 9, 2003 12:10 PM
Cross
16
Feb 28, 2002 10:34 PM
