ZEX nitrous
Old Jan 8, 2003
BaNgCiViC2k1's Avatar
BaNgCiViC2k1 is an unknown quantity at this point
ZEX nitrous
With ZEX™, you keep you hands on the wheel and your eyes on the finish line.
When armed, your ZEX™ nitrous kit kicks in at full throttle automatically thanks to the
ZEX™ Nitrous Management Unit.
So while your competition is trying to find the nitrous switch, you've already won.
Ok so let me get this straight, if i am at a stop and i floor it the n2o is injected, is that safe at that low rpm/speed
Old Jan 8, 2003
sspem2's Avatar
em2
you dont use nitrous at a stoplight cuz that means your in first gear and you NEVER spary nitrous in 1st or 5th gear cuz there the weakest gears.
Old Jan 8, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
umm lets think ?Zex~dry kit? ....Or you could go to http://www.edelbrock.com/automotive/index.html and see that they are coming out with a kit for our cars
Old Jan 8, 2003
StLVtec's Avatar
StLVtec is an unknown quantity at this point
Actually a buddy of mine has A 2001 honda civic auto, with custom intake manifold and direct port nitrous set up and he sprays in first gear and just roast the **** out of his tires , he does it for fun not when racing.
Old Jan 8, 2003
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
If you're at a stop light, the system is armed, and you floor it......then yes, it will spray.
This is bad for a few reasons:
1. Your stock clutch will probably slip.
2. Your tires will spin more so you won't take off any faster.
3. 1st gear is very very short so there's no use spraying. (most of the time I don't spray in 2nd gear either)
4. 1st gear is very weak
I have mine set up to spray at WOT. I installed it to where you really have to mash the gas before it sprays. And as an added bit of protection, I don't arm the system until I shift to 2nd.
Old Jan 8, 2003
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
how is first gear weaker than any of the other gears....i can see 5th being weaker because you dont use it as much but 1st you use ALL THE DAMN TIME
Old Jan 8, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Quote
[hr]Originally posted by: 4drcivic2k1
how is first gear weaker than any of the other gears....i can see 5th being weaker because you dont use it as much but 1st you use ALL THE DAMN TIME[hr]
That guy doesnt know what hes talking about. 5th gear is weak, but the reason you dont spray in 1st is because you get
to much tire spin, and we all know what that accomplishes, nothing. Also, the gear is very short so your really not accomplishing
a whole lot. Some people who get good at launching manage to accomplish using Nitrous in first gear. But for the most part its pointless.
Old Jan 8, 2003
nucks's Avatar
nucks is an unknown quantity at this point
ive heard that with that WOT kit, it wnt engage until a certain rpm while at WOT, the rpm u choose. so say for instance, you set it to 3800 rpms and then your at a stoplight and mash the gas, it wnt engage until you reach those rpms and then u can set it to shut off at a certain rpm as well......idk how you solve the problem about spraying in first though, [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 8, 2003
Bartkat's Avatar
Quote
[hr]Originally posted by: CivicRicer02
umm lets think ?Zex~dry kit? ....Or you could go to http://www.edelbrock.com/automotive/index.html and see that they are coming out with a kit for our cars[hr]
2001-02 Honda Civic Nitrous Wet System (40-60 hp) 71002
Performer EFI Nitrous Systems: New listings
Performer EFI Nitrous Systems are the best way to get a major power increase in your fuel injected late-model street machine. These systems work with your stock computer for a simple installation. “Dry” systems get extra fuel for the boost in hp from the stock injectors. “Wet” systems use a direct port style nozzle to introduce nitrous and fuel into the intake runner. Performer EFI Nitrous Systems include a 10-lb. nitrous bottle (shipped empty), nitrous solenoid, aircraft quality steel braided hose, nitrous filter, jet selection, aircraft quality fittings, and all necessary switches, brackets, and hardware for a complete installation. Power increase shown in parenthesis.
Old Jan 9, 2003
AEMcivic's Avatar
Ok, so 1st gear isn't that weak. Whatever. But it is easier to hit redline and f**k something up or start throwin codes if you spray in 1st. Nothing good comes from spraying in 1st in a civic. AWD is another story. It will just do more harm than good. I've known a few people who frequently sprayed in every gear (including 1st) and their tranny didn't last that long. And first gear was one of the gears that went out. So just thought I'd be safe and tell everyone that there is a risk. Of course with the stock clutch, there is less risk because the clutch will slip before any damage is done to the transmission. But whatever if you think I don't know what I'm talking about.
Old Jan 9, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Isn't there a management system where you can delay the timing of N2O
to spray? Most 60 foot times are 2.3 to 2.5
If you set it up so that it will not spray until 2.5 seconds,
you will be at full throttle in first gear and by the time
you shift to second, at WOT you will be spraying.
Correct me if I am wrong
Old Jan 9, 2003
kjgracing's Avatar
Old Jan 9, 2003
Parisdreams's Avatar
Parisdreams is an unknown quantity at this point
um lets think? Honda! Zex makes a wet system for the 7th gen civic. trust me i have it.
ttamrekab
Sep 28, 2015 01:22 AM
pimpdakota
Mar 18, 2002 05:05 PM
Cross
16
Feb 28, 2002 10:34 PM
supermex
Feb 1, 2002 09:05 AM
ACEM2
Bolt-on Engine Performance
Nov 11, 2001 08:36 PM
