A New HICUP to stump the panel. RSX Injectors + boosted Civic + Missing Link=CEL....
Old Aug 19, 2004
  #61
Hwoody77's Avatar
Hwoody77 can only hope to improve
RSX Injectors were flow-tested at 340CCs...
Old Aug 19, 2004
  #62
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Originally Posted by MadWheel
The map sees boost when you make boost. It's just within tolerance for the ECU. At about 8.2-8.5psi I would have fuel cut due the MAP sensor.
So yeah, you can run 8psi with out a missing link. But Yvette has a missing link now (or at least I know she ordered one).
Mine didnt start to freak out until a little over 9psi. So we left it at 8 till i could get my hands on one.
Old Aug 19, 2004
  #63
dezod's Avatar
7thgen Power Maker
I shoudl have some commin in sometime today. IF UPS doesn't FRUCK up again.
Old Aug 19, 2004
  #64
dezod's Avatar
7thgen Power Maker
Are you sure?
I'll have to look up my sheets from when I got them flow tested.
Old Aug 19, 2004
  #65
Hwoody77's Avatar
Didn't Opto get them flow-tested at that? Or maybe it was 320cc?
Old Aug 19, 2004
  #66
opto_isolator's Avatar
340cc's @ 45 PSI.....
Old Aug 19, 2004
  #67
dezod's Avatar
7thgen Power Maker
Where did you have them tested Opto?
Old Aug 19, 2004
  #68
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I had mine cleaned & Flow tested at Cruzin Performance for like $56 Shipped, these were my results:
To convert from lb/hr to cc/min, simply multiply the lb/hr by 10.5.
So for mine the average was 31.39 * 10.5 = 329cc
But Opto got 340cc? What would the difference be?
If you are going to be adjusting the fuel pressure, you can use the following formula to calculate the approximate fuel flow when adjusting the fuel pressure up or down:
new flow rate = (rated flow) * square root of(new fuel pressure/rated fuel
pressure)
Old Aug 19, 2004
  #69
dezod's Avatar
7thgen Power Maker
Here are my results
Old Aug 19, 2004
  #70
That seems to be about 323cc on average then. Seems to be differences, or is it in the way they were tested?
Old Aug 19, 2004
  #71
dezod's Avatar
7thgen Power Maker
It would be safe to say they are 320CC injectors. Error margin is in the users favor if more.
Old Aug 19, 2004
  #72
But mine were closer to 330, and Opto's seem to be closer to 340 I think?
Old Aug 19, 2004
  #73
dezod's Avatar
7thgen Power Maker
Yours may have had less mileage and such.....Anyway, OPTO's are a different story, his were flow tested at 340 @ 45 PSI, yours and mine were only done at 43.5 PSI.
Ours are a closer comparison because Ibid Ereubus (Sure I butchered the spelling).
Old Aug 19, 2004
  #74
Here
Old Aug 25, 2004
  #75
HyaBoosta's Avatar
so was there finally a solution? is it still throwing the cel?
Old Aug 25, 2004
  #76
dezod's Avatar
7thgen Power Maker
Read the Honda-Tech E-Manage Hack. Thats what is causing it.
Old Aug 25, 2004
  #77
HyaBoosta's Avatar
So you got it working and no cel and the injectors in and running fine?
Old Aug 25, 2004
  #78
dezod's Avatar
7thgen Power Maker
yes sir. I had another CEL, but it had nothing at all to do with the injectors. It was a delayed O2 sensor reading because we relocated one of the sensors to use a wideband for tuning purposes. I just put it back to where it was prior.
Old Aug 27, 2004
  #79
So Dezod is this the correct fix for using RSX Injectors & E-manage to get normal idle, and not the CEL, before tuning of course:
With the Injector correction feature not being used.
Old Aug 28, 2004
  #80
dezod's Avatar
7thgen Power Maker
For the most part, yes. I'd also recommend putting the same in cells for 1000 rpm & 1500 rpm for uber cold starts
Old Aug 29, 2004
  #81
What about the 100rpm, should that be included too? What is Uber?
Rpm Scale-> 0 100 1000 1500 2000 2500, etc
or
Rpm Scale-> 0 500 1000 1500 2000 2500, etc?
Old Aug 29, 2004
  #82
dezod's Avatar
7thgen Power Maker
or
uber means very
yes, 1000 rpms @ the same 2 throttle position points there as 0% throttle.
Old Aug 29, 2004
  #83
Bear with me here, so perhaps like this:
Or would this one be more appropriate to match better with the other maps, or are they the same?
Do they both represent 42% additional air between 0-3% throttle position and 0-1999 rpm?
Or is the rpm transition more linear by adjusting between 1500 and 2000? Example @ 1750 rpm it would be either 42% or 21% depending how e-manage averages it, my guess is that it would be 21% for smoother transitions between different values on the map.
Old Aug 29, 2004
  #84
C2i0v0i1C's Avatar
SuperMODrizd
have u even got a base map at all so far, i didnt read all this, anyways, get a base map, and then drive it, and then while driving the screen will blink yellow everywhere, when u hit a snag, fix and drive again, snag fix, so on and so forth, im going to try and get my base 5 psi map, i dont know how long it will take, u might already be done by the time i get it
Old Aug 29, 2004
  #85
dezod's Avatar
7thgen Power Maker
He's right . Use the real time data display and drive & data record the air flow meter input & output with RPM & TPS on the same graph. Those signals should be near identical. He is referring to realtime map trace too. Excellent function on this unit.
Old Aug 29, 2004
  #86
Sorry, I have no basemap yet, but if I do manage to get one I will do just that, it sounds like a good way to tune before getting it to the dyno for fine tuning.
Old Aug 29, 2004
  #87
Wait - don't put 42 in any number higher than 100 RPM (500 at MOST). The ECU is just looking for what the MAP and Baro sensor are on STARTUP - if you start to add a butt-load more fuel past 500 RPM you're car isnt' going to like it (when you increase that # - it increases the MAP voltage, which in turn adds more duty cycle to your already big RSX injectors).
Old Aug 29, 2004
  #88
So this should be the correct way?
Old Aug 29, 2004
  #89
civic01vtec's Avatar
damn, this is a good thread.........maybe a sticky
Old Aug 29, 2004
  #90
Yes - but, in the "0" RPM column put 42 all the way down. That way if some yahoo decides to press the gas while attempting to start the car it will still work.
