Alcohol Inj. pressure switch question *EDITED*....Answer
Old Jul 24, 2004
civic01vtec's Avatar
I want to lower the setting so it injects at a lower psi. Do you screw the allen head screw in or out ??
Old Jul 24, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
You should be able to turn it right or in to make it come on sooner for a lower psi. Im not sure but thats the way mine works with the mf2....
Old Jul 25, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
I'm not sure man I forgot...what psi are u lowering it to and y and what do u have it set at now? I have mine set at 7psi now and I NEVER turn my boost controller on
Old Jul 25, 2004
how do u know it is set at 7psi........i can't build that much boost in neutral to test it. I am thinking about hooking up a LED light to show me when it is activiated. I wanna set it at 6psi.
Old Jul 25, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
curious, those who use the washerfluid reservoir, can you hear the pump kick on every time it sprays alcohol? it sounds pretty loud when i clean my windshield, i'm just wondering if it sounds the same with the alcohol injection.
Old Jul 25, 2004
naw, u can't hear it......b/n the turbo spooling and your exhuast, u won't hear it.
Old Jul 26, 2004
JetBlu01's Avatar
New Member
we pressurized it....originally it came set at like 4.2 or something around there...didnt even have to turn the car on just took off the air filter and pipe, pressurized it and pressed the gas till we saw alcohol shooting out and just adjusted it from there
Old Jul 26, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
If you hook the hose back up to your windshield sprayers. Then go for a ride. You can see what psi you are set on when the alcohol sprays on the winshield.
Old Aug 1, 2004
OK, i finally checked mine the way that fuchs said by hooking it up to your windshield washer pisser. I hit 8 psi and it didn't spray
Anyway, here is the answer.....
Lower the psi setting..... turn the screw to the left as if u wanna loosen it.
Raise the psi setting.... turn the screw to the right as if u wanna tighten it.
Old Aug 1, 2004
Mr.Modify's Avatar
lefty loosy righty tighty
Old Aug 1, 2004
abmerop18's Avatar
Jam out with your clam out.
word to that
Old Aug 2, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
civic01vtec I am thinking about hooking up a LED light to show me when it is activiated.
Nice steal Jason- but it really works
dinsum
May 28, 2015 09:30 PM
Blazz
May 25, 2015 10:56 PM
tmort
May 11, 2015 07:13 PM
usajags84
May 10, 2015 08:11 AM
MooCoW
Nov 15, 2001 10:58 AM
