Specs For Getting JE custom Made Pistons?
K20 Member
Does anyone know what the specs are for custom JE pistons?
http://www.jepistons.com/pdf/customp...-orderform.pdf
Originally Posted by ImportRacer2123
i thought C2i0v0i1c had Crower Rods?
LOL......rods and pistons are 2 different things.......but yeah, PM Kevin
K20 Member
yeah i know dork... Jeff told me to check out the members rides for the specs but all i found was the crower rod specs... I didn't know he had JE pistons my bad.
I still dont see why people don't buy pistons from turbo specialties. They're dirt cheap and DSM owners love them. I plan on eventually buying them.
Wiseco part # XT-519P76 for 76mm
I know that they make a direct bolt on 75mm also.
They are about $500.00 for a set rings about another $100.00 for rings
Wiseco an JE are quality parts, you get what you paid for.
To install crower rods you must notched the botton of the sleeves cause the rod is a lot thicker than stock.
Originally Posted by C2i0v0i1C
if u get the 76mm ull have to bore.
but I wouldn't recomended with out stainlees steel replacent sleeves cause you'll be making your stock slevees even thinner (more fragile)
The maximum factory oversize suggested is 75.52mm
Originally Posted by HyaBoosta
so does anyone make 75mm pistons that will fit without having to bore out the cylinders?
Butterfli13
Aug 12, 2015 11:04 PM
Jul 12, 2015 11:54 AM
fvckbg
Jul 7, 2015 07:08 PM
