Oil Temp sensor in the drain plug
Old Jun 21, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I know it can be done... I've seen it done... but doesn't anyone worry about something hitting it? I guess its somewhat safe on the back of the car, but if that busts off, its all over.
So I'm just curious...has anyone on here done it, and do you ever worry about a rock or a stick? Any thing you did to shield it or something? Just wondering...
That seems the easiest way. I don't feel like dropping the pan, but I guess I could use a sandwich adapter...
Old Jun 22, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Why would you want to relocate it? It's safe from everything above the filter .
Old Jun 22, 2004
Jap-Euro Fusion
Figure out what I'm talking about first.
Oil TEMP sensor, not the PRESSURE switch.
Old Jun 22, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The sensors are pretty tough, we accidently broke one during installation of a motor. The sensor is sealed, so when the top broke off, nothing came out, it just didn't work.
I have mine in the pan with a bung hole next to the drain plug. Something would have to go under the motor and go up. But I don't really worry about it after we took the broken sensor apart. They are constructed differently from a pressure sensor, as there is no hole in the sensor itself.
RIPSAW
Nov 6, 2015 04:36 AM
Allecr3
May 22, 2015 01:24 PM
Blaster30
Apr 22, 2015 12:21 PM
silverdevil
20
Jun 2, 2007 04:42 PM
hyperactive
Feb 4, 2002 04:12 AM
