d17 turbo problems
Old May 17, 2004
js4uhaterz's Avatar
js4uhaterz is an unknown quantity at this point
d17 turbo problems
on 9 lbs boost car cuts off......check engine light kicks in.....any suggestions
Old May 17, 2004
Spider883's Avatar
9K Redline Owns U
turn down the boost
Old May 17, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Would it be the map sensor, reading too much boost on the car?
Old May 17, 2004
iamboo's Avatar
Retired - SoCal FI Mod
do you have a map sensor isolation valve on your car? if not, the car is reading boost and it will go into a "safe mode" or the car will just shut off completely... if you can, try to read the code next time you get a check engine light and refer back to us or a mechanic about the issue... if all else fails, turn down the boost and see if it does the same thing...
Old May 17, 2004
js4uhaterz's Avatar
well, done that already....my next thing is to buy a missing link and see if that works... runs fine its just at 9lbs when your creeping into boost it happens....if your at full throttle it doesnt happen
Old May 17, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i had that back in the day, i have a missing link, when it hits boost and it is seen by the computer, car just jolts and rpms make they way down to zero, just get a missing link and i bet the problem will go bye bye
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
