Internal Wastegates?
Old May 17, 2004
HyaBoosta's Avatar
Question Internal Wastegates?
Is a boost controller of any use with an internally wastegated turbo? i know the wastegate is preset to 8 psi but is there anyway to raise it or will it always be set there?
Old May 17, 2004
civic01vtec's Avatar
internal wastegates are adjustable via the rod with the nut on it.
Old May 17, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
What he said... but if you want better response at a higher psi, or want more than one setting, get the boost controller.
Basically put... a boost controller can only stop an amount of air from reaching the actuator, and can't force it. So it can only be a boost setting at or higher than what the wastegate actuator is already set for. That is also to say until the point the internal wastegate starts to cause boost spikes. A preset of 8psi for this car sounds way to high. Best bet would be to set it low, and use a boost controller to go higher. Again, depending on the turbo, exhaust, and everything else, a boost controller should give you a quicker response by taking care of any boost creep.
Old May 17, 2004
HyaBoosta's Avatar
so my best bet would be to turn the nut on the wastegate down and maybe get a turbo xs mannuel controller and rasie it up when needed?
C-Hamm
Sep 28, 2015 10:31 PM
