High Boost....Wont kill ur car after 20,000 km...
Old Apr 16, 2004
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Post High Boost....Wont kill ur car after 20,000 km...
http://www.honda-tech.com/zerothread?id=786174&page=1
He's still running >10psi and running some stock internals......
I've been confused to why most of the ppl on this board who have SF kits or other Turbos say...."stock internals wont last" why do you all think our D17's are so weak???
Has your car died on you yet?
Do you have proof that stock internals wont hold up???
Because I am planning or purchasing a SF kit but it seems that there is soo much financial upgrades needed in order for this kit to be usable and not have ur engine damaged.....
If you run 25psi...I could logically see why you would need to upgrade stock internals....but even running 12psi what's to say a car wont last on stock internals for years?
Some of the B's on that site have stock internals and are running 12psi...are DOHC so much better than our D's SOHC.....
I really want to see proof that our cars will die...if we run 10psi on stock internals...that's about all....just proof that we need to do all these upgrades....I understand it's a good idea to upgrade internals...but is it necessary because our engines are that weak???
Old Apr 16, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
hmm i want input on this also...im saving up for boost..
Old Apr 16, 2004
Hawk's Avatar
You boost, I-VTEC
20,000km is not a very long time, whats that like 16,000 miles? i do that in a year.
Heres the setup:
B18B1
STOCK head
Endyn Pistons 9:1(those arent stock)
STOCK rods
GE blockguard (thats not stock)
Skunk2 intake manifold
Crower cams
ferrea valvetrain
Precision SC61
680cc injectors
2.5" downpipe thermal 3" exhaust
hondata s200
Pump gas 93 octane
Thats like 700 bucks in aftermarket parts that will make his motor last alot longer under boost. Sure you have to tear the motor apart, so another $600-$700 for labor probably.....
i'm just gonna stop, forget about it. I'm not gonna bother trying to save people money...
*edited*
Old Apr 16, 2004
chrisgushue's Avatar
Bring Hockey Back!
chrisgushue is an unknown quantity at this point
blow your engine have fun
Old Apr 16, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
The guy also had aftermarket valve-train.. Which helps under boost also. I wouldn't run 12 lbs for a LONG time without changing internals. You are running the engine into the ground doing that, IMO.
But then again it's just me.. So, do it if you feel it necessary.
Old Apr 16, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
If stock internals held up under boost then the aftermarket piston, rod, and crank companies would be out of business. Boost takes life off of your engine no matter how you drive. True, driving your car like your 78 year old grandmother would prolong the death of your engine but totally defeating the purpose of spending a lot of cakes on your turbo kit. More air and fuel in the cylinder chambers just means a hotter fire with an end result of more hp/torq. Also leaves you with shortened engine life. That I am sure everyone and their dog knows.
If your buying a turbo kit, why not spend the extra money to support the boost you will be running? Sure, SF kit is about $3k these days then you need gauges, boost controller etc all of this keeps adding up. Save yourself some headaches, buy the internals.
Old Apr 16, 2004
Hawk's Avatar
You boost, I-VTEC
hey someone else who sees the light!
Old Apr 16, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Asianpride, you raise a good topic....
Have you examined in person a D17 rod? Have you compared it in size and strength to an aftermarket one?
Have you examined a stock D17 piston? Have you compared it to an aftermarket piston?
Has anyone else? I would like to see your opinions on the differences....
Have you read the posts about people popping head gaskets? Wanna know why people are not popping rods out the side of the blocks yet? Headgasket sealing issues.... The HG will go MUCH sooner than a piston or rod... Get the HG to seal and then see how long the bottom end live...
I'm always up for a good debate so I suggest this: run 12lbs, get the HG to hold, and go 40K miles... Oh, and run a compression test.... Then get back to us.... I think there will be quite a few people here that would be interested in your results....
Old Apr 16, 2004
Texas Rice's Avatar
I lay down old information for peopl, Hawk. =p
Jonnie.
Jan 13, 2019 11:21 AM
usajags84
15
Aug 19, 2015 03:12 AM
vtechcivic
Apr 21, 2015 06:58 PM
2Hondaz
Nov 8, 2001 11:00 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
