is there anyone that has SF kit has CEL
Old Jan 31, 2004
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
My cel is always on...since mine is lx....i put the cat too....but the light is still on....u guys has the same problem?
Old Jan 31, 2004
turbo1zz's Avatar
turbo1zz is an unknown quantity at this point
remove the battery cables from the battery and let the car reset. return the cables and start the car up. If you continue to get a CEL then something is not hooked up right or you knocked something loose. You should not have a CEL at all with the SF kit.
-Jeff
Old Jan 31, 2004
rscivic's Avatar
rscivic is an unknown quantity at this point
My light has been on for about 5 months, every time I reset it it just comes back on again. A friend at Honda ran the codes and pretty much it is just the different air flow and running a little rich that the ECU cannot read- nothing bad- oh and I have an EX. Nothing bad going on just a confused ECU IMO.
This is nothin that some black electrical tape can't fix
Old Jan 31, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I have 2 CELs one for the IAT sensor not being hooked up (SF doesnt drill a hole for a gromet and connector) and one for o2 voltage. The IAT sensor needs to be hooked up I plan on drilling a 1/2 inch hole in the charge pipe and using my old AEM gromet and connector to connect the IAT. Go to autozone they run code scans for free.
Old Jan 31, 2004
C2i0v0i1C's Avatar
SuperMODrizd
my IAT sensor is still in the original place that AEM has it on the CAI since thats what im using as the upper pipe, its going to get relocated to see if it helps
Old Jan 31, 2004
Your Parts Guy
you still have a CEL for it in the AEM location?
Old Jan 31, 2004
civicskater's Avatar
Chicks dig my scent
i thought the CEL would come on no matter what if the cat was removed,and on a LX the cat is removed...or is it just where the sensor bung holes are placed it gets a clear reading?
Old Jan 31, 2004
C2i0v0i1C's Avatar
SuperMODrizd
like right at the bottom of the pipe or at the top of the TB right there, yea its still there right now
Old Feb 1, 2004
Your Parts Guy
**** looks like ill wait until you move yours to see if it works...
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
if u dont have them in or dont have them plugged in it will show the light, also if the second 02 shows a worse reading than the first it will light up also
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
im having a new radiator, fan, hoses, clamps, all put in here in a week or so, so dont get anxious
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
Re: is there anyone that has SF kit has CEL
whats that lil box between ur battery and the fuse box
Old Feb 1, 2004
Your Parts Guy
having meaning you arent doing it yourself???
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
no, i dont have the ability
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
1. they dont make after market radiator for our car
2. therefor i dont have a welder to make supports
3. i havent installed anything in the engine bay, except the original AEM CAI
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
plus the 5 inches of snow on the ground here and the single digit temperatures round here, would get me in the garage to even try
Old Feb 1, 2004
leonhsieh's Avatar
it's the mf2 fuel kit....
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
Luluharp
Sep 27, 2015 11:56 AM
anubis62
Sep 27, 2015 12:56 AM
