Emanage + SF Fuel system...UPDATED!
Old Jan 6, 2004
MadWheel's Avatar
Premium Boosted Member
Will this still be tunable? I bought the Emanage and want to tune it with the Stafford setup... Hopfully I can fix some problems... Any suggestions for settings? Any tips on the install? I got it yesterday and should receive it this week... When I have enough cash to buy the pressure sensor and ignition harness I'll be dyno-tuning it at a local shop... Looking for about 200whp when done... 9psi, with alcy, full exhaust... retard the ignition and remap the fuel curve... hopfully I can do it...
Old Jan 6, 2004
C2i0v0i1C's Avatar
SuperMODrizd
did u get the support tool, if not u have to have it in order to tune everything u listed
Old Jan 6, 2004
MadWheel's Avatar
I did buy the support tool.
Old Jan 6, 2004
C2i0v0i1C's Avatar
SuperMODrizd
Re: Emanage AND SF Fuel system...
Originally posted by MadWheel
Will this still be tunable? I bought the Emanage and want to tune it with the Stafford setup. Any suggestions for settings? Any tips on the install?
yes it will still be tunable, do u have any other type of fuel controller, if so ditch it, i dont know much about the SF fuel kit, but if it just comes the the vortech FMU, yea ull be fine with the emanage, as for settings, i dont know at the moment, boosted2k2 is good help on that, seeing as i dont have my car here with me, install tips, just do a good job bc if dont things can go bad, sauter(SP) the wires, where do u plan on putting the unit, i got mine under the passenger seat, zip tied to the floorboard
Old Jan 6, 2004
MadWheel's Avatar
thanks for the tips.... if this clears anything up... in a simple way... i'm pretty sure the sf setup works by adding 10psi of fuel for every 1psi of boost... should i talk to them about tuning?
Old Jan 6, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Madwheel is your car working again or whats up with it...?
Old Jan 6, 2004
MadWheel's Avatar
Yep. Works awesome now, better than the day I installed it. Resealed the oil pan with red silicone. Redid the oil feed lines, cleaned up everything and check the vac. lines. Car runs perfect.
Old Jan 6, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Old Jan 6, 2004
C2i0v0i1C's Avatar
SuperMODrizd
yea i would ask them bc i think the emanage would electronically override the mechanical fmu, but then again i dont know how SF fuel kit works
Old Jan 6, 2004
MadWheel's Avatar
according to SF... about 250whp on my parts is attainable... the emanage works very well with the fmu and pump he sent me...
will post results
Old Jan 6, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
yea please do..
Old Jan 8, 2004
MadWheel's Avatar
Project put on hold. Makin a lil too much power hehe. Clutch slips at 37-3800 now. In the process of getting the ACT Stage 2 clutch and pro-lite flywheel.
Old Jan 8, 2004
C2i0v0i1C's Avatar
SuperMODrizd
this is great
Old Jan 9, 2004
MadWheel's Avatar
Bought the Stage 2 ACT clutch with Xtreme disc instead of street disc. Bought the ACT 8.2lb prolite flywheel. Bought the phantom grip LSD.
Emanage came in. It's the JDM spec lol... Says trust on it...
Old Jan 9, 2004
civic01vtec's Avatar
the sad thing is, u are still running no more than 4.5 psi
Old Jan 9, 2004
MadWheel's Avatar
No I was running 7.5 (mid spike) and 5psi towards redline. I had a really sh*tty mbc and SF told me the seat of it just isn't sealing correctly. Buy yeah, at 37-3800 7.5psi then it would shoot up to 6k and because im makin lest boost pretty much sit at 6k the whole time. Making 0 psi right now (took the actuator rod off hehe). Installing everything next week.
Old Jan 9, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
that the rod is off and the wastegate is left open?
while ur not making boost to the engine , the turbo is still spinning and spinning it is! its spinning as fast as it wants ...
your gonna blow up ur turbo.
someone correct me if im wrong.
Old Jan 10, 2004
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
where did you get the prolite flywheel?
Old Jan 10, 2004
MadWheel's Avatar
Dezod.com
Old Jan 10, 2004
MadWheel's Avatar
You're wrong. lol. But it is spinning, just not making boost.
Old Jan 11, 2004
zinkyroo's Avatar
cool beans
Thats not good...
Old Jan 11, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
you guys dont get how a wastegate works. The exhaust gas is being diverted around the turbine. That means that the turbine is spinning very slowly, thus making no boost, and still safe for both the car and the turbo.
Old Jan 12, 2004
MadWheel's Avatar
Told ya hehe. Hey cat, does that mean I know how a wastegate works? lol... Sorry guys... just feelin good that i knew that haha...
but yeah... im makin about 3psi right now...just till the clutch gets replaced this friday. I'm not even driving the civ anyway. It's in my garage till the clutch gets installed. Driving my dad's car for the week, he's on vaca so he said it's cool. I'll def have new vids of lightened flywheel revs and my clutch... latas
Bman2212
Sep 2, 2015 11:49 AM
cwisenbaker06
Aug 19, 2015 04:29 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
