MAJOR problem, please help...
Old Dec 18, 2003
MadWheel's Avatar
Premium Boosted Member
Late last night, my Engine light came on... car ran as though it was out of gas, wouldn't rev past about 3300... Idled like **** (sparatic).... I reset the ECU then the car ran fine. I just let my car idle outside about 10 min ago... Went to sit inside of it and the light's back on...
I look under the car after jackin it up... Oil all over the bottom of the engine, and engine mounts... I'm pretty worried about the car now.. Gonna wipe everything down and see if I can find the leak/leaks... I've installed the turbo with new oil, then did an oil change about 800 miles ago... All of a sudden something went wrong last night... I wasn't even beating on my car... It's raining here so I've been gentle...
Any ideas on what's wrong? I'll be looking at it for a while...
Old Dec 18, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
could the oil bung for the feed line be lose, or installed incorrctly??
Old Dec 18, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
yeah bro...that t is SOOOOOO important.. double check that first...
Old Dec 18, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
uh ohh....keep us updated....nice video by the way. I am hoping it is just an oil
line that busted..
Old Dec 18, 2003
MadWheel's Avatar
i really don't know what that is...
I checked everything... Filled the car with another qt of oil. My A/F gauge stopped working too...after playing with the wires it works again, BUT i still have the oil issue...
I'm gonna buy a new pan, new bolts, and red silicone sealant. The oil feed line just start leaking, it's leaking where the brass fitting goes into the turbo (came that way). If I take it out and bead it with silicone I hope to solve that problem. I will update daily so keep checking. Hopfully I can grab pics tomorrow...
Old Dec 18, 2003
Jodster's Avatar
Post Whore General
If you oil line came messed up than shouldn't SF be able to help you?
Old Dec 18, 2003
andyman97's Avatar
Turbo Guru
Hopefully you weren't running too low on oil for too long. Could have damaged a ring or a piston.
Old Dec 18, 2003
MadWheel's Avatar
Any aftermarket oil pans? If I can score my grandfather's 97 hatch for a while then I may attempt throwing my turbo on a K24.
Old Dec 18, 2003
sexcivic2k1's Avatar
my problem exactly, going to swap another D17a2 this weekend or the next
Old Dec 18, 2003
MadWheel's Avatar
god damn this cursed setup...
If I can't fix this... Either a K20A3 (SI), and put my turbo on that, or turbo charge and attempt a K24.
Old Dec 18, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
this is scary im in the middle of my install right now...what the hell went wrong?
Old Dec 18, 2003
MadWheel's Avatar
Lets just say this... Car can barely idle. There's oil all around the pulleys on the drivers side... Oil around some parts of the pain, aoil coming out of the oil feed line, a messed up primary o2 sensor... that's all i can think of for now... off i go to research some motors...
Old Dec 19, 2003
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Compression check, and then do a leakdown test. That'll tell you if anything internal to the motor could be messed up.
Sucks to hear, hope it's something simple. If you want and need to replace with another D17, I know a source you can get a block and head pretty cheap.
Old Dec 19, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
did you get any oil on the MAP sensor isolation valve? If so, that is causing your idling problems and your not being able to go past 3000 rpm.
I found that out the hard way. When you get oil on it, it acts incorrectly. It thinks you are at full throttle when in fact you are idling.
If that is what it is, let me know. I will hook you up with a new one.
I also agree with riceburnerex. Compression and leakdown test will tell you if anything is wrong. And the fitting in the top of the turbo should be sealed with teflon tape. If you turned it backward AT ALL while installing the kit, it will leak. Just take the fitting out, re-teflon it, then install it again Making sure it is tight, and DO NOT back it out at all once it is tight.
Old Dec 19, 2003
EnProceso's Avatar
sucks to hear the bad news about your car bro, hope everything works out! keep us posted.
Old Dec 19, 2003
MadWheel's Avatar
Here's the update: Motor will be ok. Didn't find oil on the Map sensor but I will look into that more this after noon.
I'm buying a new oil pan and redoing the flange for the oil return. I will be taking the oil feed line out and re-taping it for the leak issue. I'll wipe everything down and see if it fixes my problem. Once I do all this I'm buying a beater, then sending my engine to DHracing for the turbo shortblock. If I have enough money I'll have it ported at the same time.
Either way I'm fixing the motor I have. If it starts to develop probs again without doing anything else to it, I'm gonna swing for the K20A3 or K24. Then send dimensions and whatnot to SF for a new turbo manifold so I can turbo that motor.
Time will tell guys. I appreciate all of you support.
Old Dec 19, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
Damn... Sounds like a plan man.. Good Luck...
Jon-Ohio
Jun 30, 2018 08:10 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
mrohitredd
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
lapchern
Bolt-on Engine Performance
Dec 22, 2001 06:23 PM
