when my turbo spool i hear weird noise help
this just started like 2 days ago. when my turbo spools i hear this weird noise, the noise sound like someone is gargling. Then after 5min of driving it goes away. This happens everytime i start my car and go. what do u guys think it is??????? need help
i dont know much about turbo, but could it be that you turned off you're car without a turbo timer? Thats the only thing that I can think of, and when you start you're car again the five minutes that it takes to stop is the oil regaining circulation. Like i said i dont know much, but maybe thats the problem.
I have an sf setup and I know that my fuel pump makes a similar sound from time to time. If it only does it when you start it up, try letting the car warm up before you start boosting.
I do let my car warm up first. its like a rateling noise can't explain it. my car feels find. a/f says its rich all the time when i'm on boost. lets say my car is warm up already and drove it for 30min. then stop the car and turn it off for 10min. Then turn back on and i hear that rateling noise when i spool up then it goes away after i drive for 5min. I do have a turbo timer too. what wrong wit it.
Well, first thing, the a/f gauge is worthless. It's so inaccurate it doesn't read anywhere near correctly. Do you have a full sweep fuel pressure gauge? Make sure that if you do, the gauge adds 10 psi fuel pressure for every psi boost you run when the turbo is making the boost. I know that my sf fuel pump is pretty loud and I notice an almost static sound when the turbo spools and the fuel pump is adding pressure to the rail. It probably isn't anything serious. As long as the car is running right I wouldn't even worry about it other than maybe laying some dynamat behind the pump where you have it mounted at.
dude i noticed today that my BOLTs were missing that connect the downpipe to the wastegate... some times **** just happens..
having a turbo'd car that wasnt turbo'd before is a never ending process.. you gotta always be checking this and that... ya know.
well went to sfpower shop today and the vales was making the noise. i just need to get it adjusted. is ther a DIY to adjust ur vales???????
SSMatey
Apr 13, 2015 06:09 PM
DC5@EM2
26
Jan 22, 2002 10:44 PM
Aznnp77
Jan 7, 2002 03:12 PM
PimpBot5000
Nov 26, 2001 07:15 PM
