K20 K24
Old Oct 9, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
K20 K24
what is the difference between a k20 and a k24? What does a k24 come in?
Old Oct 9, 2003
Mr.Modify's Avatar
the difference between a k20 and k24 is that there a 3 numbers in between the K20 and the k24!! (sorry just being a ***)
Old Oct 9, 2003
atl01's Avatar
so you really dont know?
Old Oct 9, 2003
Mr.Modify's Avatar
i can't think of the exact difference ri now ...lemme go do some researching !!
K20 VS K24
Old Oct 9, 2003
Mr.Modify's Avatar
there man!!
hope that helped ^^^^^^^^
Old Oct 9, 2003
atl01's Avatar
so the RSX-S has a k20, Does the RSX non S have a K20 also. i think that the K24 is the C-RV motor.
Old Oct 9, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
Yes, the non type-s RSX DOES have a k20. It may have the same displacement (2.0 liters) as the type-s version but it is only rated at 160Hp instead of 200HP. This difference is due to a higher compression and a different cylinder head design with a more advanced i-vtec (in the type-s).
The K24 is very similar to the K20. This is apparent in the "K series" designation. It has a displacement of 2.4 liters. I think you can catch on to Honda's naming scheme. It gets this larger 2.4 liter displacement by utilizing a longer stroke. This typically gives more bottom end torque at the expense of high RPM horsepower. It also has different variations like the one found in the CRV and the one in the TSX.
Old Oct 9, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i don't know but if the come out with a TSX Type S, the engine will come with 240hp...
Old Oct 9, 2003
TSX type-s at 240HP... that sounds about right. It is what most people expect. Honda has proven time and time again that they can pull out atleast 100HP per liter without too much trouble.
Old Oct 9, 2003
Got Boost???'s Avatar
To answer the mans question
The K20 engine is a 2 liter engine available in 3 different forms: the K20A is in the Japanesse Integra (RSX) Type-R which makes 220 hp, the K20A2 is in the RSX Type-S which makes 200 hp and the K20A3 is in the base RSX and Civic Si which makes 160 hp
The K24 is a 2.4 liter engine that is used in many Honda and Acura cars such as the new Acura TSX, CR-V, Element and the Accord. Right now there is only 1 K24 engine and thats the K24A1 which makes 160 hp and 162 ft-lbs of torque which is a good bit of torque for a Honda
Old Oct 9, 2003
Jodster's Avatar
Post Whore General
^^^^^^you got everything right but one thing. There are two K24 motors that I can think of. The K24A1 out of the CRV, Accord, and Element which make 160hp and 162 tq. And the K24A2 out of the TSX. It makes 200hp and 165 tq.
Old Oct 9, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
k24 pretty much comes in all the other hondas except for the odessey, civic and insight... and maybe the pilot.. but in the hondas, the k24 puts out 160hp and not sure how much torque, its 2.4L not sure if it has a single cam ivtec like the k20a3 or dual cam ivtec like the rsx type s
Old Oct 9, 2003
Jodster's Avatar
Post Whore General
the K24 in the CRV, Accord, and Element are DOHC with VTEC on the intake cam only like the K20A3 in the SI. The K24 in the TSX is basically the K24 block with the k20A2 head on it. So it is a DOHC with VTEC on both intake and exhaust cams.
Old Oct 10, 2003
^^^yep. If you add up all of these posts, you have ALL the answers to your original question. Atl01, you now know what the engine's names are, what power they output, and what cars they are found in.
Old Oct 13, 2003
eddie5spdx's Avatar
eddie5spdx is an unknown quantity at this point
Wow! I think instead of wanting a K20 I think I want a K24. 200hp and 165 of torque sounds nice doesn't it???
Old Oct 13, 2003
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
the TSX has 200hp and 165ft lbs but the accord and the CR-V and the Element have 160hp and 160ft lbs the bigest differnce between the motors is conprestion, and dicplacment with the K20, go to www.kbb.com to find some more info
Old Oct 14, 2003
Originally posted by Drivetofast
conprestion
= Compression (I hope)
Old Oct 15, 2003
Alex1's Avatar
In other words, it gets more torque, period!
Old Oct 16, 2003
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
just for pricing info purposes
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
Old Oct 17, 2003
eddie5spdx's Avatar
Thats the reason i want the k24 from the tsx because of the torque.
Old Oct 18, 2003
Stone's Avatar
Stone is an unknown quantity at this point
The K24 from the hondas (Accord, insight, element, etc) is a lot more common than one from a tsx.
I would buy a K24 from one of those and a RSX-S head and swap it on.
Probably cheaper and easier to find, but you never know, sometimes you can find good deals. An Acura engine is probably going to be more expensive, because of the name.
justcruzin125
Aug 11, 2015 09:09 PM
Inkubus
Bolt-on Engine Performance
Jun 30, 2015 12:11 AM
kenji4861
Dec 29, 2002 01:55 PM
Freshguju
98
Nov 11, 2002 10:09 AM
briang
Oct 31, 2002 03:24 PM
