K20a2 Swap!!!!
Old Oct 14, 2003
  #31
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
yeah i can get him to show u the sswap
Old Oct 14, 2003
  #32
mad03civic's Avatar
mad03civic is an unknown quantity at this point
Yall know what i done said F**K it and i am gonna get DHRacing to do a custom intake manifold, head work titanium retainers, and race springs for $1,500 and then take the other $3,000 that i have left over and get a SF Turbo and be done with it
Old Oct 15, 2003
  #33
rasper's Avatar
rasper is an unknown quantity at this point
yea i seen a swap done for $3000. u just need get hookup with the engine.
Is that a K20A2 swap? How and where did you get a "hookup" on that? I'm interested in that swap for $3000. I see K20A2's listed for about $4000-$6000 with tranny. Guess I need to find a "hookup".
Old Oct 15, 2003
  #34
Jodster's Avatar
Post Whore General
This is the parts list you will need off of www.hasport.com
Parts Needed
- K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
I myself am looking at doing this swap. I plan on buy the small parts over the winter and spring and getting the motor in the summer. I'm still not sure if I want to do the install myself.
Old Oct 16, 2003
  #35
Elite's Avatar
Elite is an unknown quantity at this point
Originally posted by RiceRocketeer
Elite, if you don't mind, would you tell me where you got all the parts for your Tranny Swap, I'm looking to do one and your price range sounds about the kinda territory im in.. I wanted to know if you could hook me up with a list of parts.. Thanks man, If you want IM me on aol or yahoo : MightyMouse585 and we can talk there or PM me, or just make a thing here.
Thanks again,
RiceRocketeer
I got all my parts from a local junkyard btw, but I got new clutch and flywheel, pressure plate, throw out bearings n stuff. I was thinking instead of putting the regular shifter I can get myself a revo ss. oh btw some mechanic will do it for me 350 total labor costs.
Old Oct 16, 2003
  #36
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
Jodster...HASport was nice enough to leave out a bunch of stuff on that list. Be ready for suprises, have an extra couple grand in the bank after all that is bought just to have for little stuff. Or you can just buy my wrecked car, and not even worry about those little part, or if the motors gonna work, or how to do the wire harness modification, and get TEINs, with rims and new tires and a bunch of other stuff.
Old Oct 16, 2003
  #37
Hawk's Avatar
You boost, I-VTEC
lies lies lies! hasport leaves out so much stuff that you need. And their instructions are horrible.
But don't take any swap advice from me cause i can't even get my damn car to turn over, just cranks and cranks and cranks.
FYI. I have 6500 tied into my swap...but i had/have a whole RSX so i got the interior, brakes, motor/trans/ecu/wiring harness, and all the little nonsense parts...which there are ALOT.
Old Oct 16, 2003
  #38
Hawk, you should sell all your stuff, and just buy my civic with a working K20A2...i will give it to you for the going price of 10K...thats a fully working complete motor swap with CAI and exhaust, TEIN coilovers, rims that are all still good but one that has some scratches, new tires literally put on last friday, and so on. The engine bay alone on my car is worth about 7 grand. You buy my car, and you would have a working K20A2 in your car in less than a week...all you would have to do is transfer all my stuff into your car. Even comes with a battery to mount in the trunk. Just a thought....
Old Oct 16, 2003
  #39
Hawk's Avatar
You boost, I-VTEC
10 GRAND!
what do you think i'm made of money? I'm broke as a joke after this ****, i mean hell i had to take out a loan just to get the motor.
i already have a motor in my car all i have to do is figure out whats wrong, its something electronicly.
Sell it to someone who doesn't have a k20, if anything is goin in my car it's a d17, if my motor doesn't work.
Old Oct 17, 2003
  #40
i knew that buddy, i was just playin.
Old Oct 17, 2003
  #41
Hawk's Avatar
You boost, I-VTEC
I was gonna say, i thought you were goin insane
Old Oct 17, 2003
  #42
i will be selling my D17...everything is there with the motor except the wire harness that i cut up to modify the RSX-S one. Im probably gonna sell that for maybe $400 if that.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
