Boost spikes and BOV's
Old Oct 1, 2003
RiceBuRNeR's Avatar
Turbo Member
Im having a lot of trouble w/ boost spiking. At around 4000 RPM's I make 9 psi and then the waste gate opens and my pressure drops to 5-6 psi. Do you think that If I installed a "pop of valve" that limmits boost to 9psi I could turn up my boost controller to make full boost through the rest of the powerband?
Here's the pop of valve Im looking at. valve
Can the greddy tytpe S be use in the same way? It has the secondary port as well...look here
Or should I use this
Old Oct 1, 2003
C2i0v0i1C's Avatar
SuperMODrizd
ur spiking 3-4 psi
Old Oct 1, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
The GREDDY RELIEF VALVE looks pretty good.
Old Oct 1, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
this has nothing to do with this post but riceburner`s car is the ****!!! i was gonna go with orange paint too.......luck punk, your car is nice man
Old Oct 1, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Type S BOV is the shizzle yo!
Old Oct 2, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
what boost controller are you using
Old Oct 2, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
ditch the manual boost controller, and get an electronic one. MB's are known for not being able to hold boost
Old Oct 2, 2003
RiceBuRNeR's Avatar
Turbo Member
Im using the $100 version of yours ( Turbo XS).
Im hoping that I can just get the greddy relief valve and then turn up my BC a few turns.
BTW: did you ever think about those CAD drawings? (need to know soon, Gotta pic a project drawing for class)
Old Oct 2, 2003
ohmysac's Avatar
yeah i think i'll have you do one...mine is gauranteed not to spike...if it does just send the unit back (write return to sender on envelope and they'll be no charge) and i'll refund your money...
i'll cut you a deal...20 bucks shipped and a cad drawing...hows that sound?
Old Oct 2, 2003
RiceBuRNeR's Avatar
Turbo Member
^sold! we can work out the details through PM.
Old Oct 3, 2003
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
Riceburner just a simple suggestion it may be best for you to get an electronic controller as someone else stated. Many of the newer units have functions that not only allow boost control but allow you to set gain per rpm in the various gears. Although more expensive going to a electronic boost controller in my rx-7 as opposed to a manual helped greatly.
Old Oct 3, 2003
Not to mention that you don't really want to rely on your bov to control your boost. It's simply there to keep your turbo from experiencing compressor surge. To properly control boost you want to rely on a good boost controller/wastegate combination.
Old May 7, 2004
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
whats compressor surge sound like?
Old May 7, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
gettin a manual boost controller with fix that ... my buddy had the same problem in his H22 turbo accord .. he had an XS manual one and he upgraded to a greddy Profec B much easier to deal with.
Old May 7, 2004
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
^^^huh.i think you mean electronic boost controller.
Old May 7, 2004
abmerop18's Avatar
Jam out with your clam out.
manual boost controllers are very hard to work with not to mention how inaccurate they can be. most manual boost controllers require a trial and error to get them correct since you have to keep setting it and checking the boost with you gauge inside, while with an electronic boost controller you just set it and know that the boost you selected is what you will be running.
Old May 7, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
You also have to consider weather and air temp with a MBC. Mine spikes at 12psi when it is cold dense air. Hot and humid I am good if I get 10psi. Something to think about when summer is around the corner.
Old May 8, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
IF your pressure is dropping off way too earlier is your wastegate... damn... so many amatuers... naw j/k... but after working around DSM's way way too much... i can tell you right now an electronic boost controller is a waste... it's just for if your a lazy *** and wanna turn up ur boost inside ur car... you need to fix the wastegate to not fully open at only 4000 RPM.... do some researching on wastegate probs... and u'll figure out how it is very easy and free to fix....
Old May 8, 2004
civicskater's Avatar
Chicks dig my scent
^^Right on, running a 5psi actuator when i spike at 8 it'll drop til 5psi and stay there from 4500rpm-redline...my dual stage XS boost controller was always set at either 4.5psi or 8psi and did not creep, all i did was had a custom actuator made to open only at full boost, which in my case was 8psi and the actuator dropped me to 7psi
Old May 8, 2004
REDchirp's Avatar
See.... told ya... finally i had good input on a question for once!!! I am feeling like god for a sec, now two...... damn now it's gone!!! oh well
bowie
Jan 21, 2018 09:29 PM
Islesfan
Sep 29, 2015 03:42 AM
C-Hamm
Sep 28, 2015 10:31 PM
jerry38
Sep 20, 2015 08:38 AM
99BoostedSi
Sep 7, 2015 04:49 PM
