Sf kit install today. PIX
Old Aug 6, 2003
  #61
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
oil pan 2
Old Aug 6, 2003
  #62
RoBBUsaF's Avatar
engine bay
bay
Old Aug 6, 2003
  #63
RoBBUsaF's Avatar
intercooler
front shot of intercooler
Old Aug 6, 2003
  #64
IDQcivic's Avatar
IDQcivic should not be trusted
hey whats that wire you have running right through the manifold?
Old Aug 6, 2003
  #65
RoBBUsaF's Avatar
I think its for the knock sensor. It comes off of the top of the turbo and I decided to run it up instead of under because when I ran it under, it was kind of tight... actually, I think i ran it above because when I ran it under most of the wire was around the headers/downpipe/midpipe and didn't want it to overheat or what not. I hope it doesnt matter which way I ran it...
Old Aug 6, 2003
  #66
Stone's Avatar
Stone is an unknown quantity at this point
Rob, I know we dont have to tell you this but, if you get some numbers... post it!
Old Aug 6, 2003
  #67
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
ConGrats!!
Old Aug 6, 2003
  #68
RoBBUsaF's Avatar
as soon as i get everything where i want it i will take it to the dyno. i hope it can get on the dyno.... i cant even go over speed bumps... lol...
youll have numbers by the end of september if all goes right. im kind of broke right now. =)
how's your turbo comming Speedracer??
Old Aug 6, 2003
  #69
WannaBFast's Avatar
Prowlin' with a Purpose
how was the fit for the ex? i hope its what we come to expect from the Stafford kit
Old Aug 6, 2003
  #70
RoBBUsaF's Avatar
the fit was good. the only thing I had a really hard time puttin on was the pipe that went from the turbo to the intercooler... BUT that was only because I got the upgraded turbo which is bigger... Mike said they are comming out with a fix so I am not worried... Because it is a tight fit, the coolant hose is somewhat pinched but I havent had any temperature problems... yet... Stafford rocks... period. They are always there to help me even when they are so busy. I know i must annoy them... haha
Old Aug 6, 2003
  #71
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Unhappy Sorry Robb....
Sorry Robb for hi-jacking this thread, but I needed to let everyone here know that I have a complete SF Power Turbo kit for sale in the ForSale/Trade forums for $2,000.00. It comes with everything and slightly used. I have not gotten to put it on yet, as it's still coming to me from Derek-CEO. But I am going through a rough time and need to re-sell it ASAP.
Once again I am sorry Robb.
Old Aug 7, 2003
  #72
Maverick's Avatar
Maverick is an unknown quantity at this point
Well Robb, I got my SF kit on today...everything is running smooth except my midpipe can't screw in all the way to the down pipe off the turbo...the bolts hit the pipe because it's much fatter than the stock down pipe, sooo i have a lil gap. I'm gonna try and cut the springs down on the bolts to see if that works, if not i need to find a bolt in that same pitch etc...noew my check engine light is on, i hope it's because of the exhaust leak
is your regulator kinda loud?mine is...constant humming...is this normal?
so far i have it up to 4 psi while i break it in, will move up to 6 in a day or so...pulls hard, i'm officially a boosted convert,thanks mike...i will up load some pics soon...as for the dyno, you'll get it when you get it
Old Aug 7, 2003
  #73
RoBBUsaF's Avatar
cool. im glad you got it in. can you give me a diagram of where the wires go on the relay on the fuel system? im getting it back today and i need to know where all the wires go. thanks mav. as for it being loud... that is supposedly normal... it is the vibrations passing through to the body. i think Mike said that if we put a rubber washer between the mounting, it will be less noisey. i had a check engine light. i went to the dealership.. it was running to rich but that was good... but i did get rid of it by resetting my ecu again and leaving the car idle for like 10 min to be sure... if thats not it then yea its probably because of the pipe not connecting... your o2 sensor is in your cat.
Welcome to the family.
Old Aug 7, 2003
  #74
Maverick's Avatar
my red wire went right to battery, green to ignition under steering column and black to a ground...my friend jason wired it up while i was cutting my bumper so i didn't see exactly where he grounded it...
yeah, mine was running a lil rich last night but not too much
Old Aug 7, 2003
  #75
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
Hey Ken, I'm glad you got it running fine last night. Maybe shorter bolts will fix that exhaust problem, you can probably still use the same springs.
Old Aug 7, 2003
  #76
Entropy's Avatar
Entropy is an unknown quantity at this point
here's a question for you turbo owners, since our cars were running 32 - 35 mpg, how many miles to the gallon do you get now with your turbo, since your running more fuel and all?
Old Aug 7, 2003
  #77
Maverick's Avatar
i haven't run it enough to tell yet, will let you know once i go through a tank of gas
Old Aug 7, 2003
  #78
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Catalyst said he gets around the same for the city, and a little better on the highway
Old Aug 7, 2003
  #79
funkeemunkee's Avatar
funkeemunkee is an unknown quantity at this point
Originally posted by Alex1
i dunno about u guys... but i wanna know what happen to Rob's car. i'm assuming it blew up. but pls tell me not Rob! if it did, that's a loss for team iLLRaTeD.
iLLRaTeD = hella gay
Old Aug 7, 2003
  #80
RoBBUsaF's Avatar
lol... illrated is hella gay.
Old Aug 7, 2003
  #81
andyman97's Avatar
Turbo Guru
The thing to remember is that you're only consuming more fuel under boost so if you don't run it hard, you should retain very close to stock numbers.
Old Aug 7, 2003
  #82
SFpower's Avatar
Former Sponsor
SFpower is an unknown quantity at this point
we have actually experianced a slight gain in mpg on the freeway, and it stayed the same around town.
Old Aug 7, 2003
  #83
rscivic's Avatar
rscivic is an unknown quantity at this point
I have gone a 1/2 tank and am @ 150miles- this is no highway driving and in a manual tranny. This is the exact same as w/out the turbo
Old Sep 15, 2003
  #84
KYjerry414's Avatar
KYjerry414 is an unknown quantity at this point
Where did you get the turbo kit? I'm really interested in one. Some guy told me about SF performance but i havent been able to find information on it.
Old Sep 15, 2003
  #85
IDQcivic's Avatar
you gotta open your eyes, like every thread here mentions the SF kit.... its the best kit out there for our cars....
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
Youshoe
May 22, 2015 09:36 PM
Jigee
May 9, 2015 11:18 AM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
SneakerPimp
Nov 3, 2001 10:57 AM
