K24 + jrsc fitment?
Rep Power: 0 K24 + jrsc fitment?
Just as the title states, I'm very curious to see if there will be any issues with clearance when I do the swap. I mean I know I have to trim a bit of the radiator support but that should be about it right?
Busy Speeding!!
1 Post
Rep Power: 170 Re: K24 + jrsc fitment?
The worst that could happen is you need to cut a hole in your hood and put a fiberglass bump there. People will ask why and then you get to brag about how your engine is so big it doesn't even fit in the car
Rep Power: 291 Re: K24 + jrsc fitment?
Just make sure to buy an aftermarket hood that gives you more clearance. I don't know how much space you will have for the SC anyways, the K is a tight fir in the car. Doesn't really leave room for much else. I'm sure it can be done. Check out K20.org. they must have more info on this.
Rep Power: 0 Re: K24 + jrsc fitment?
Looks like the evil plan might just be possible > Currently following a build thread for a k24 + cte blower. We'll see if he can fit in in or not!
