Got a small problem
Old Feb 25, 2004
JohnnyLee's Avatar
7thgen guh chee
Exclamation Got a small problem
I just got 18"s installed on my car and I realized that my stearing wheel shakes like it is having spazams. It only happens when I am on the freeway and on certain parts of the freeway it dosen't shake at all. It use to shake a little with my stock steelies. Does anyone know why it shakes? Is it because the freeways suck ? BTW My car is lowered and I never got the car alligned after i got it done. Some of my brothers friends say that I just need to get my allignment done and it should be cool. I just don't want the brand new tires getting messed up or the wheel coming off while I am driving. Any suggestions would be nce.
Thanx
Old Feb 25, 2004
VTECTypeR's Avatar
MY 18's did the same thing. I think its cuz we need hub centric rings or something or u need it rebalanced. One of those two
Old Feb 25, 2004
Mr.Modify's Avatar
mine do it to but not that bad.
Old Feb 25, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
you need to get your wheels balanced, should only cost you 40 bucks max
Old Feb 25, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
yup align the car.... and check ur bushings
i just learned that in my suspension class
Old Feb 26, 2004
iamboo's Avatar
Retired - SoCal FI Mod
rebalance your wheels...
take it to the place that mounted the tires on there and they should do it for free cause that's messed up...
Old Feb 26, 2004
JohnnyLee's Avatar
7thgen guh chee
Rebalance it is....
Old Feb 26, 2004
iceman's Avatar
--< GripSpeed Member >--
u need to get an alignment or rebalance done
Old Feb 26, 2004
VNlilMAN's Avatar
The Standard One
i would go with rebalancing... when i got my 18s, i took it back to the shop 3-4 times and they couldnt fix it so they gave me $20 to take it elsewhere. i took it to america's tire and they fixed it. turns out they were putting the weights only on the inside when they were supposed to put it on the inside and right behind the face of the rims.
Old Feb 26, 2004
JohnnyLee's Avatar
7thgen guh chee
thanx for the info guys!
Old Feb 26, 2004
XtremeJM's Avatar
Yeah definantly get them balanced and then if iot continues check the allignment, but i had the same problem and it just needed to be balanced.
Old Feb 26, 2004
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
Another thing, check and make sure you tightend all the lugs. I know that sounds simple, but one can get missed or one doesn't fully get tightened. This is very common if you use a socket gun and don't torque or hand tighten after. But most likely it needs to be balanced and alligned.
Old Feb 26, 2004
Nodnero's Avatar
Yeah, exactly. Check and make sure all of the lug nuts are on tight. ALT didnt set mine on all the way, and when I drove off, my wheels were making this nasty noise. So I got out, tightened them, and they were fine.
Old Feb 26, 2004
LiLaSiiAn8's Avatar
you need those stupid rings.. ask ak
Old Feb 26, 2004
HondaLuver's Avatar
Its a celebration bitches!
u sure the small problem isn't in ur pants, and shouldn't this be in the wheels, tire and brakes fourm?
Old Feb 26, 2004
egot2da4th's Avatar
egot2da4th is an unknown quantity at this point
97-DX-Lover
Jun 14, 2015 06:07 PM
DouglasTheGreat
May 27, 2015 11:23 PM
Blazz
May 25, 2015 10:56 PM
Ma213802
May 18, 2015 07:01 AM
