Boost/HP
Old Dec 14, 2024
Shatto's Avatar
Shatto is an unknown quantity at this point
Boost/HP
I’m building a k20 to be a track/weekend driver.
i just want to know how much boost I can put to it and how much hp it’ll be able to make without it blowing up after a few months. I just want it to last a couple years without it blowing up.
The Specs:
Stock k20z3 block
Stock k20a2 Crankshaft
Wiseco Forged pistons 11.6 compression
Forged rods stock length
Drag Cartel Street Head
.030 head gasket
Old Dec 17, 2024
BrotatoChip's Avatar
Super Moderator
Re: Boost/HP
How much power are you looking for? K20 with forged bottom end will hold up to quite a bit. If on track, don't be revving it to the moon (for longevity).
From experience, 9 psi on my K24 makes 365 whp and 306 lb ft. It's too much for on track. Torque steer like crazy and the brakes give up after 10 minutes, even with a big brake kit. I usually detune to 6 psi.
Old Dec 17, 2024
Shatto's Avatar
Re: Boost/HP
Well I’m planning on reducing the weight in it as well. It’ll likely be a track car when I can make it to salt lake. I also planning on swapping my rear drum breaks with discs and front and back with both be on big breaks. So I’m thinking that I’ll likely do what you did and just keep it at low boost. Thank you!
Old Dec 17, 2024
Re: Boost/HP
salt lake? so drag strip, not track (with corners)
Old Dec 17, 2024
Shatto's Avatar
Re: Boost/HP
They have a motorsports complex there that’s an actual track. I’ve thought about doing a light drag build but I like turns. It’ll also be in a couple road races depending on my work schedule.
Old Dec 17, 2024
Re: Boost/HP
didn't know that, thanks!
So what year car do you have? Curious
Old Dec 17, 2024
Shatto's Avatar
Re: Boost/HP
It’s an 8th gen LX coupe that died on me. I have a special spot in my heart for the car. so I won’t let it go down. I’m practically swapping an Si frank build into it.
CinnamonSpanklz
Engine building
Mar 9, 2017 10:09 PM
98lxbuild
Mar 30, 2013 11:05 AM
FREESPIRIT
Engine Swaps
May 24, 2010 10:03 PM
NashVegasEX
Engine Swaps
36
Apr 9, 2005 02:56 PM
UnOrthodox9546
Engine Swaps
26
Sep 8, 2003 02:01 AM
