$2500 worth of boost insurance ...
Old Apr 4, 2005
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
well, the machine shop has all my parts .... its my $2550 turbo shortblock... All I need for the head are springs/retainers ...
Engine Head $120*
Valves - Manley $271*
Springs - Crower $176
Retainers - Crower $120
Seals - Honda $ 35*
Head Assembly $500*
w/Resurface, Valvejob, PnP
Engine Block $185*
Sleeves - Darton $248*
Rods - Eagle $415*
Pistons -Diamond 9.1:1 77mm $468*
Piston Rings $ 90
Cometic Head Gasket $150
ARP Main Studs $150
Machine Rods and Sleeves $500
w/ Bore, Hone, Notch, Deck
Assembly/Build $350
w/ Block Decking, Balancing
____________________________________
$3778
$2292* paid for
Old Apr 4, 2005
HyaBoosta's Avatar
how did you get the crower parts before they came out and where did you get your internals and a cosmetic gasket? I've been looking for a while for my build
Old Apr 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
special order will get u anything u want, ive got a set of rods sitting under my bed that are damn near 2 years old, from crower for the d17, so i mean anything can be gotten, most of the time they require samples, i had to send a stock rod with my order. same with the pistons, JE, i sent a stock piston to them
Old Apr 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
77mm thats a big bore. and of course that would lead to a special order COMETIC
Old Apr 4, 2005
the Crower springs and retainers can come off a D16z6, the sleeves came from Race Engineering, the reground cam is Crower, the head/block from a salvage yard, the rods are modified GSR Eagle rods, the pistons are custom ordered ++oversized by Diamond, the valves are SI (the company, not Civic Si) or Manley, Honda OEM bearings... All I need to order are the main bearings and the head gasket (going to be a custom order from Cometic) .... We're going to press in the sleeves while we're waiting for the pistons to get in ... 1.8L 9.1:1CR
Old Apr 4, 2005
kezay's Avatar
kezay is an unknown quantity at this point
The spring and retainers from Crower are the same from older model d series engines...
Old Apr 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
how do u modify a GSR rod for a d17, are u shaving **** off or what, i mean thought would weaken them
Old Apr 4, 2005
SOOOOO true ...
Old Apr 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
is that a question or a statement.
we need to get a thread going that has proof by numbers of all the interchangable parts from the d16-d17
Old Apr 4, 2005
HyaBoosta's Avatar
^word. I don't think I'll spend the money on valvetrain till I find a way other then ems to raise the rev limit.
Old Apr 4, 2005
you mill .039 from the big end width on each side of the rod ... you also tell the piston maker that you need the 77mm piston to accept a 21mm wrist pin instead of 19mm like the stock D17a2 rod ...
And we're only milling .078 off the new rod so we dont have to worry about weakening at all ...
Old Apr 4, 2005
kezay's Avatar
Yeah that is what Brian (Crower) told me.
Old Apr 4, 2005
same here ...
Old Apr 4, 2005
kezay's Avatar
There must be a way to raise the rev limiter on our ECU's or at least disable it.. Let's drop Hondata an email asking if they could either disable it or raise it and see what we come up with?
Old Apr 4, 2005
HyaBoosta's Avatar
The only other part I know works from a D16 is the clutch and pressure plate.
Old Apr 4, 2005
HyaBoosta's Avatar
Hondata doesn't want anything to do with us and none has found a way to chip the obd2 ecu's without going thru the obd1 conversion and we can't do that.AEM came out with a ignition system for coil on plug ignitions like ours that allows us to raise the rev limit but I haven't seen it out for sale yet or know if it works for us for sure. Alot of the evo guys use it. But without raising the rev, there is no reason that we would really need valvetrain.
Old Apr 4, 2005
I believe my valvetrain is the future (sung to we are the world) .... We wont always have a rev-limiter and when we don't, I don't want to redo my top-end so now is the time ... If there was a forged crank out, I'd get one of those also ...
Old Apr 4, 2005
HyaBoosta's Avatar
just get yours micro polished
Old Apr 4, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Cam Specs?
Old Apr 4, 2005
Originally Posted by Havok2k1
Cam Specs?
search for Crower cam specs... I posted it like a year ago and I'm at work now...
Old Apr 5, 2005
Cam Specs?
This thread for regrind specs
Old Apr 5, 2005
kezay's Avatar
I personally think that Hondata can remove the rev limiter in our ECU's because the K Pro and our ECU have a lot in common....
Old Apr 5, 2005
According to hondaautomotiveparts.com the D17a2 (2001-05 EX) and the D16y8 (1996/8-00) use the same valves, retainers, and exhaust springs but the intake springs are different .... dunno why its different, just know that it says it is ... Crower makes a valvespring set for the D16z6 and D16y8 ( it states D-series VTEC ) so thats what I'm going with ...
Old Apr 8, 2005
HondaChevy's Avatar
HondaChevy is an unknown quantity at this point
Ever heard of Scat cranks?
Old Apr 8, 2005
C2i0v0i1C's Avatar
SuperMODrizd
yes i have, but honda cranks hold up quite well stock. ive seen one hold 500+whp for 3 years straight
Old Apr 8, 2005
HondaChevy's Avatar
My point is also rotational mass--make everything that turns in a circle as light as possible without sacrificing integrity. A billet crank that is knife edged and balanced would be a good addition and be relatively light in weight don't you think?
Old Apr 8, 2005
C2i0v0i1C's Avatar
SuperMODrizd
well yea u are right, but for a car where no crank is made its nice to know stock cranks can handle alot in the mean time
Old Apr 8, 2005
HyaBoosta's Avatar
too bad our tranny isn't as lucky
Old Apr 8, 2005
C2i0v0i1C's Avatar
SuperMODrizd
personally i want to see how much power i can get, and see how long it takes til i have to drain the fluid and i get gears falling out with it!!!!!!!
Old Apr 8, 2005
HyaBoosta's Avatar
lol thats the spirit. I broke my dam shift fork in my tranny N/a. So i swapped it out but im going to fix the fork next week
