Rev-matching vs. Double-clutching
I don't understand how rev-matching without putting the car in nuetral helps. I've heard that it isn't necessary to double clutch with modern cars for smooth downshifts but I am under the impression that the speed of the layshaft won't change unless you double-clutch. So what I'm asking is for someone to explain how rev-matching without double-clutching works.
Autocross Junky
Re: Rev-matching vs. Double-clutching
The synchros match the shaft speeds, thats their job. So on a syncornized gear box, double clutching is unnessisary.
Though if you do double clutch, your synchros will last a bit longer. Especially so if you do multiple gear down shifts.
I usually double clutch but in my new car the revs drop so fast (and I get free maintenance for 50,000 miles) I am thinking about just rev matching without releasing the clutch.
i rev match...but what ive noticed about alot of people who drive manual is that they dont rev match at all and the car(wheels) and engine speed dont match and it jolts the car hard...when downshifting that is
Rev matching is key if you don't want to upset the chassis. This is a very big ordeal when you are talking about sport bikes. I would think that it would be important for cars as well.
I rev match with heel-toe most of the times that I downshift, even on my accord when I can't really reach the gas pedal from the brake. It just makes you a ton better at heel-toe when on the track.
Dave88LX
Electrical
15
May 28, 2020 08:31 PM
jordan1794
Jun 11, 2015 09:14 PM
Wild Cranker
May 19, 2015 06:10 PM
