Overrevved way past the limmiter...
Old Jul 8, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
WEll, I was on the top of 3rd gear at about 6800, and then I accidentally shifted into second! I think the rpms went way past 8500, but nothing happen (knock on wood) . Anyways, I let off as soon as I saw, it was not even for a second. Could there be anything wrong?!? It drives fine, but I am worried about fried pistons or vavles. I checked, and the head gasket has no leaks that I could find for now. What do you think?
Old Jul 9, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
If your car runs fine and there are no weird ticking noises (messed up valves) coming from the engine, I think you're ok.
Old Jul 9, 2003
bublik's Avatar
Truehonda.com
fhheeeew, no ticking noises I think. Well, I want to take it to Honda and have them hook it up and see what I actually revved to? Wonder if it is a bad idea?
Old Jul 9, 2003
NoFriends's Avatar
I like ruining your threads.
better safe then sorry. ive never had the misfortune of over-reving, just a few ground gears here and there from trying to shift too fast. :-\
Old Jul 9, 2003
civicdude's Avatar
Wrong Forum...going to Street Forum
Old Jul 9, 2003
NismoSpecV's Avatar
NismoSpecV is an unknown quantity at this point
Re: Overrevved way past the limmiter...
You have no idea how jealous I am of the Honda/Acura motors...I would give my left nut to have a 7k or 8k redline.
Old Jul 9, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
Re: Re: Overrevved way past the limmiter...
we are jealous of your torque and hp!
Old Jul 9, 2003
Green Civic's Avatar
You should be ok. If you were in 4th and went to 2nd, then there would be a problem. You will kill the engine and computer if rpms go over 10 or 11000 rpms. Just be more careful next time.
Old Jul 9, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
Hmm... I have never done anything like that, but wouldnt the fuel cut keep the engine from going over 7500 RPMs? And the computer doesnt lock the shifter from entering 2nd??
Old Jul 9, 2003
YES's Avatar
YES
YES is an unknown quantity at this point
fuel cut has nothing to do with the gear making the engine turn that fast. computer locking out shift gates? umm...?
Old Jul 9, 2003
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
lol.. well that goes to show if there are no problems... then we CAN hit higher rpms stock.. people.. reset your rev limiters.. lol
Old Jul 9, 2003
bublik's Avatar
Truehonda.com
well, it seems fine. I never gave it gas, I actually just let it grip the high rpms (accidentaly of course) and threw the clutch in faster than a fat man running from healthy bar. bad joke. ANyways, shift at 9200, bc that is what I hit. The dealer hooked it up, and said it was impressive but dangerous. I still have a warranty, wait, nope, the no2 is there.
Old Jul 9, 2003
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Long time ago i did that too but i was in 4th going into 5th. But my car does have a ticking noise. Is that bad? I think there my lifter ticks going out.
Old Jul 9, 2003
YES's Avatar
YES
naa u just need a valve adjustment. take off the head if u have the tools to realign it, otherwise take it to honda.
Old Jul 10, 2003
NismoSpecV's Avatar
Re: Re: Re: Overrevved way past the limmiter...
The torque and hp is a nice feeling but having to shift so many damn times when running someone really sucks. I get owned by my friend who has a 2000 SI with i/e all the time. He is still in 2nd and I am shifting into third. The power doesn't kick in until about 5k RPM's for our car, so until them it is a very slow death.
Old Jul 10, 2003
doublins's Avatar
doublins is an unknown quantity at this point
Let's hear it for VALVE FLOAT
It's times like this when you should be VERY happy that you have a low displacement 4 cylinder engine with lightweight parts. Because if you did that to most other cars, you would float a valve faster than you could say "oh sh*t".
Old Jul 10, 2003
Im not sure. If you shift quick enough, the car's computer cannot stop you. Ive seen people blow their engine because of that.
Old Jul 11, 2003
YES's Avatar
YES
thats a huge piece of misinformation if i ever saw it. computer has nothing to do with the actual gear forcing the engine to turn above 7k (caused by a misshift)
Old Jul 11, 2003
FSRbikr98's Avatar
FSRbikr98 is an unknown quantity at this point
back when i first got my car, i raced some kid in a 95 civic with altezzas and a few tv's, i was beating him thru 2nd, thru 3rd, went to shift to fourth and accidently went back into second, i was speechless because i've never heard my car scream like that before. I pulled over, listened to it for a minute or two, decided nothing was wrong, and that was the first and last time that will never happen. Its been well over a year and the only problem my car has had was a defective tranny.
Old Jul 11, 2003
Sure it was defective
Old Jul 12, 2003
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
get a compression test kit for $40. it will be your best friend, and it will tell you if anything is abnormal.
Old Jul 14, 2003
FSRbikr98's Avatar
lol K20 yes it was defective, there was a faulty "throttle release bearing" and the transmission needed to be replaced. Honda took care of it under warrenty only because i looked in the extended warrenty booklet and saw that the part they were talking about was covered
Old Jul 14, 2003
BumpinCivic2k1 where can I get a compression test kit?
Old Jul 15, 2003
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
dood, i let a friend of mine drive my car, and he hit red line first, second, third, then went back to second , i knew he could drive stick, but he screwed up terribly this time. ever since then he hasnt driven my car again, anyways, i saw the needle go soooo far past the 8 grand mark, if u were looking at a clock the hand was at about six o clock, crazy, but my engine was fine, no smells weird noises. so i pulled his *** out of the car and drove the rest of the way home.
eric
solarpunk70
Apr 12, 2016 11:43 AM
Zygrene
Mar 22, 2016 12:36 PM
danace99
Oct 17, 2015 02:51 PM
raymondxcho
Sep 29, 2015 09:00 PM
pilebuck13
Sep 21, 2015 10:45 PM
