4th gen DOHC ZC boost build eg hatch
Old 06-09-2013
  #31
zc-eg's Avatar
zc-eg is an unknown quantity at this point
Re: 4th gen DOHC ZC boost build eg hatch
more pictures of the notched block
got the springs in
Old 06-11-2013
  #32
zc-eg's Avatar
friend of mine was porting my oil pump put a whole in it.
went to a shop to get my oil pump welded today. only charged me 10 bucks cash.
Old 06-11-2013
  #33
sl33pyriceboi's Avatar
this thread is so epic. keep up the good work.
Old 06-12-2013
  #34
Prelude Owner
GolNat's Avatar
Love all the pics! Everything looks great!
Seems like you shouldn't have friends help any more. They seem to break things
Old 06-14-2013
  #35
zc-eg's Avatar
thanks man!
thanks man!
haha i know, right? everytime!
Old 06-14-2013
  #36
zc-eg's Avatar
cleaned and assembled the oil pump and cleaned all the shavings from the block.
heres pictures of the ports and manifold from the other day.
started with this
then
heres the bent valve
rounded the edges on the girdle
Old 06-18-2013
  #37
zc-eg's Avatar
started assembling the block today. I decided to just use that oil ring that had a chip on the end on the most bottom. i filed it down so it was smooth. this time i got all the pistons in real easy.
now im still waiting on parts to arrive.
Old 07-03-2013
  #38
zc-eg's Avatar
before port matching
polished and buffed the bars on the plenum
cleaned and painted the manifold with silver aluminum high temp paint
sanded, polished, and buffed the fuel rail
painted the block and head with the high temp silver aluminum paint
head torqued down, valve train all assembled, have to do the valve lash still.
painted the old timing marks black, painted the 16* mark red and the 14 and 18 marks white.
4 coats of dark grey high temp paint, wet sanded between every coat, didnt turn out as nice as I had hoped.
Old 07-16-2013
  #39
zc-eg's Avatar
photobucket pictures now work again!
heres the motor in the car!
Old 07-16-2013
  #40
Prelude Owner
GolNat's Avatar
That looks nice!! Really clean looking bay! Did you fire it up yet?
Old 07-16-2013
  #41
zc-eg's Avatar
Thanks! tried too, it wouldn't start. cranks has spark and fuel. I'm checking the timing.
Old 07-24-2013
  #42
zc-eg's Avatar
had trouble idleing for the first bit, it would slowly stall. took quite a few times of letting it run to get it to idle steady at 7-800 lumpy as ****.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1414& transactionid=1374726417-991997728&posted_by=_www.civicforums.com&youtube_v ideo_id=qND1-whaky0[/autostream]
Old 07-30-2013
  #43
Drew0306's Avatar
Drew0306 is an unknown quantity at this point
Great pics! The internals look good.
Old 07-30-2013
  #44
zc-eg's Avatar
Thanks!
p06 converted to p28 socketed for hondata s300
hondata s300
cold start idle
running temp idle
Old 07-31-2013
  #45
Prelude Owner
GolNat's Avatar
Mmmm Hondata!!
Great to see that your using all the right parts.
bowie
01-21-2018 09:29 PM
Dave Brabant
20
10-06-2015 12:44 AM
BBrosario
09-17-2015 07:51 PM
yyyktk1
09-12-2015 04:02 PM
99BoostedSi
09-07-2015 04:49 PM
Quick Reply: 4th gen DOHC ZC boost build eg hatch
