How to stop sub from sliding around trunk?
Old Jun 21, 2006
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
Well, my sub completely destroyed my trunk. The carpet has completely been ripped out and all the the screw things are bent to ****. But now without the carpet there, it slides around a lot easier on the wood. I already put a piece of wood in the front, so now it slides left to right in the back half of the truck, and jumps around on every bump I hit, any idea on how to keep it in place?
Old Jun 21, 2006
PCaly2112's Avatar
PCaly2112 is an unknown quantity at this point
bolt it down using L-brackets
Old Jun 21, 2006
EclecticVISIONS's Avatar
EclecticVISIONS is on a distinguished road
no no no, better than l-brackets... go to a junk yard and get the hood latches from a jeep, i prefer a nice cj-7 hood latch myself. attach "loop" section to sub (or in my case, tool box) and "hook" section to trunk floor. makes for an awesome DIY and, in my case, you can remove your toolbox quickly and easily. yes yes, you may rep me for that one:-D
Old Jun 21, 2006
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
cheapest easiest and most practial way to do it is to go to home depot and get some industrial strength velcro to stick it down.. and then you can take it out easily if you need to also
Old Jun 21, 2006
or or or, get a small asian child to live in your trunk and hold it... that's the JDM way
Old Jun 21, 2006
01vic's Avatar
!! ^ +1 for that
Old Jun 21, 2006
ricanswt's Avatar
ricanswt is on a distinguished road
another +1 rep
Old Jun 21, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
You must do some mad e-braking, yo.
Anyway, just get a flat piece of rubber, maybe a cut up winter mat or something, and put it under your sub box. It won't slide then.
Old Jun 21, 2006
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
lol whatever you do asian child or L brackets have it bolted down. If your system is stolen most insurance companies wont cover it if it wasnt bolted down.
Old Jun 22, 2006
Sinisterdexter's Avatar
I Pinch.
Sinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of light
I've got the small asian child... I tried to bolt his feet to the chassis but I just can't quite get him to stop squirming enough to hammer his feet down.
Wait... Did you mean Bolt down the sub?
Old Jun 22, 2006
alpinecivic2's Avatar
alpinecivic2 is an unknown quantity at this point
ite dude, i had the same problem. i used a pretty cheap fix, but it works amazingly. idk about yours, but my cardbord plate that goes over the spare tire was bowed in pretty bad. anyway, i cut two 1x4s and just used very small screws and screwed them to the bottom of my box running parrallel on each side front/back. it works really well man, no more sliding and more importantly nothing is being damaged! hope this helps, ill upload pix soon
Old Jun 22, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Im getto.
I use my stock jack & just sorta pry it in between the top of my trunk & the box.
Old Jun 22, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
just stop caring about it and you wont notice it anymore.. thats what i did. i had the same situation too with the screws being bent and the carpet notthere just glue the carpet onto the cardboard.
Old Jun 22, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
yes sir, thats how i have minee
Old Jun 23, 2006
02BLKCIVIC's Avatar
HAHAHAHA! Your new Avatar is the **** DJ!^^^
Old Jun 27, 2006
triplethreat's Avatar
triplethreat is an unknown quantity at this point
look at the real problem
If you get some decent subs and box with some weight on the magnets you wouldn't have to worry about it movin around. Mine is heavy i can barely get it in and out.
Old Jun 27, 2006
FERIOHHHHHHHHHH's Avatar
FERIOHHHHHHHHHH will become famous soon enough
if you got some good stuff just give em to me =] that'll help it from moving around your trunk.. i dont mind them moving around in my trunk at all =] if you got some weak $hit then just throw them away if it bothers you that much
Old Jun 27, 2006
Civicman1988's Avatar
make an L bracket and screw it to the floor.
Old Jun 27, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
i had the same exact problem when i first got my em2. the carpet got ripped around those holes and all the studs got bent. since then ive been made crazy about weight reduction and i removed everything from the truck and the backseat, built a new box and fabbed some aluminum brackets that bolt to the floor where the backseat used to be. i had some cheapo l-brackets back in the day. they came out after a launch in a race ripped the screws right out of the box and the box went flying to the back of the truck. my amp was mounted on my box so all my wires got ripped out. the rca jacks on my signal converter got wrecked. was a fun experience.
Old Jun 27, 2006
karizzle's Avatar
Pinkslip Racer
u have any pics of the new setup?
Old Jun 28, 2006
i sure dont. ill get some pics and post.
Old Jun 28, 2006
diskreet's Avatar
Im all about L brackets and some screws.
Old Jun 28, 2006
i was until my experience. it was with an off the shelf box anyway. i didnt think l-backets would cut it with the dope *** box i built.
Old Jun 29, 2006
I Pinch.
One of these days I'm going to re-lay my trunk. Right now I've just got the stock crappy cardboard. I want a nice MDF floor though.
Old Jul 4, 2006
thats too much weight
Old Jul 4, 2006
_Viper_'s Avatar
Use pamela andersons old implants and put one on each side of the sub box. This might cause a dramatic increase in weight but at least the sub will stay put..
I think she has them for sale on e-bay lolllll
mjdiaz89
Jun 21, 2016 09:26 PM
15EXCoupe
Jul 30, 2015 12:59 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
cukaracha
Jul 17, 2015 05:48 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
