this is just the start
Old Jan 16, 2006
  #31
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Well at least you learned from your mistakes. You should have seen my headlights when I shot em. Like a smart guy I grabbed and then dropped it while it was tacky. Lets just say wet sanding was my life for half a day lol.
Old Jan 16, 2006
  #32
retry with hi temp paint and then this time make sure you sand the plastic before you paint otherwise the paint wont stick.
Old Jan 16, 2006
  #33
MajinB's Avatar
Drunken Master-7thgen Ninja
i thought the whole point of primer was to stick to stuff and for paint to stick to primer? wtf? am i wrong?
Old Jan 16, 2006
  #34
Mutha Fn FBM 85's Avatar
Ride BMX
strike one try again lol.. good effort. spray farther away.
Old Jan 16, 2006
  #35
D5cIvIc's Avatar
ok since you already know that you screw things up a lot, talking about the amp, maybe JUST MAYBE, you should READ up on things before you start them....just a suggestion
Old Jan 16, 2006
  #36
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
i painted my heat shield with high temp paint and it burned alittle bit, it didnt actually burn off, but i could smell it burning for awhile.. maybe because though i didnt let it dry long enough before i drove the car.. its fine now though, the paint is still on and it doesnt smell/burn anymore.
Old Jan 16, 2006
  #37
MajinB's Avatar
hmm. well lets say i did. and lets say i screw up sometimes. not alot. i did my own revo install. did my own intake. my own grill. and some other ****. so lets say i read up on stuff. and then lets say that i don't care if i screw up cause its fun for me. thanx for the suggestion.
Old Jan 17, 2006
  #38
Rennen's Avatar
New Mod on the Block
revo ss, intake, grill, and the other **** you talk about are straight forward and are basic things that anybody with apposable thumbs could do. he's just sayin that you should read up on things so that you have an idea of how to do things before you do them blindly.
Old Jan 17, 2006
  #39
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
jesus stop the bashing. just try it again dude, theres only one way to get good at something
Old Jan 17, 2006
  #40
Ride BMX
i know lol.. leave him alone if he doesnt get it right by the 3rd time.. then you can bash on him.. you learn from your mistakes.. people are better then other people at different things.
Old Jan 17, 2006
  #41
Tragedy's Avatar
skate or die
Good choice of color. I painted mine the same, but if you do not use clear coat, it can accumulate dust, and oils making the surface rough like mine. Good thing you can start over easily though..
Old Jan 17, 2006
  #42
familycar's Avatar
yes you need to sand before you primer. then sand the primer then realistically primer again and sand again then paint then sand then paint then clear. its a process. if you want it to look good take your time. i did the interior of my s10 and it took a bunch of sanding and primering to fill in the texture. you can find a filler primer as well so you dont have to primer and sand soo much. but you still want to have a clean smooth surface before you decide to paint. i used about 10 coats of clear on my interior to ensure that thick glassy look
Old Jan 17, 2006
  #43
ragingSPAM's Avatar
I just burnt my tongue
put it this way
you shoulda sanded the valve cover with 600 grit and water before priming (you didnt even need to prime) after sanding with 600 grit you could just spray it with bulldog adheasion promotor and than spray going back and forth with a 50% overlap about 6-8 inches away...
Old Jan 17, 2006
  #44
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I did mine hi temp ford red and clenaed the plastic with alcohol, I didnt sand or prime. After a few years, it still looks good and I always clean it with window cleaner. I have a EX but I have a spare LX one laying around incase I wanna go sleeper, ha ha!
Old Jan 17, 2006
  #45
Oh ya, the trick is light coats and wait longer that 1 minute between coats, mor like 10 miniutes or so.
Old Jan 17, 2006
  #46
MajinB's Avatar
ok, i waited an hour between each. maybe too long? idk. it don't matter. the thing is being stripped as i type. and i don't mind the bashing, cause we all know i suck at painting. what i do mind is when some say i screw up alot. like you know me, and all the things ive done.
Old Jan 18, 2006
  #47
scatman's Avatar
Still in the game...
holy overspray batman
Old Jan 19, 2006
  #48
05_ CivicJDM's Avatar
Don't worry about it dude, just take your time and try it again... It'll come out fine.
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
