Sliding on ice (HELP)
Old Nov 27, 2005
kelvin1262003's Avatar
kelvin1262003 is an unknown quantity at this point
Exclamation Sliding on ice (HELP)
Since my last thread got shut down, I decided to start a new one. Does anyone know how to control your civic if you so happen so slip on ice (automatic though).
Old Nov 27, 2005
dacivic's Avatar
dacivic is an unknown quantity at this point
Get snow tires and don't drive too fast.
Read this tirerack.com Tech section http://www.tirerack.com/winter/tech/
Old Nov 27, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
in ice?? thats a bit tough.... depending on how fast youre going, you can dial in some counter steer but be prepared to turn the wheel the opposite way in a split second.... and dont slam on the brakes.
Old Nov 27, 2005
dirtySAMURAI's Avatar
I log in from time to time
drive slower and dont try to act cool by sliding in the snow. that's stupid and can lead to an accident.
Old Nov 27, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
the only thing good for ice is studded tires and that is it you can have any other tire and they all perform the same on ice(like sh*t)
Old Nov 27, 2005
ragingSPAM's Avatar
I just burnt my tongue
last time i checked ice was very slipery in my hand from a cup of ice water...but than again that the most ammount of ice we get here in cali hahah...anyways just drive slowly, use chains if needed, dont panic and hit the brake and avoid driving as much as possible
Old Nov 27, 2005
dre2600's Avatar
If you begin to slide, -avoid as much as possible touching the brake-, you can maybe try to throttle in less, but if you panic and hit the brake you could induce a spin and you might not like that. Your best bet is low speeds and ice tires. Start braking signifigantly before you come to a stop behind another car to avoid sliding into him, watch lesser-used residential roads (they tend to get salted/plowed less, lots of ice). Once you start sliding on ice you essentially have no traction, if you can keep the car straight you might be okay, if you can maybe try to point it in a certain direction that might help too. Counter-steering does work to a certain extent, but if theres anyone else on the road it would be ill-advised to do that, plus the *** of the car might come around on you.
Old Nov 27, 2005
Well, rite now I have some Nordic Tires, they're suppose to be winter tires I can't really tell da differnce until i brake. It's a bit better but once i slip on icei just can't do anything when i'm Turning too, i run into da curb.
Old Nov 27, 2005
AlienX's Avatar
AlienX will become famous soon enough
i found that when ur *** starts coming out, give GAS !! as much as possible, it should pull you a bit forward causing it to come back in.. practice this a little bit in an empty parking lot so you know how the car is going to react, this might cause you just to go sideways but its better then 360. Like i said b4, go to a parking lot and practice some extreme driving after a good snow fall.
Old Nov 27, 2005
jameslinkinpark's Avatar
jameslinkinpark will become famous soon enoughjameslinkinpark will become famous soon enough
the best advice i can give is if you're gonna spin out just turn into the spin. if you try to go the other way, you'll slide all over the place. Just be safe and dont do anything stupid. ice is unpredictable, even if you do think you know how to handle it.
Old Nov 27, 2005
you're supposed to turn the wheel in the direction you're skidding so the tires catch traction for a second but doesn't always work. Use brakes very carefully but if you're on pure ice there's no chance really. In an auto you can always take off in D2, cause that will start and keep you in second gear which takes longer to get going.
Old Nov 27, 2005
i say walk to your destination cuz you will probably get there faster and you can point and laugh at the people who are sliding into stuff or cant get up hills.
Old Nov 27, 2005
ya i avoid snow driving anyway i can
Old Nov 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Put your foot on the GAS not the brake and gently correct.
Old Nov 27, 2005
just think when the flying car is made available for mass production the only thing we will have to worry about is turbulence and the others zipping around.
Old Nov 27, 2005
Mutha Fn FBM 85's Avatar
Ride BMX
Old Nov 28, 2005
Pitman's Avatar
Pitman is an unknown quantity at this point
Drive slow homie.
Best bet when driving on ice is drive slow, from the past few winters, I've seen dudes going atleast 60mph on icy *** roads, they wilding out. I've driving grandma status in the winter, no more than 20mph thru heavy snow roads, 20mph gives me enough control to make stops, and sudden turns.
ThatGuy913
Sep 28, 2015 05:35 PM
General DIY
Sep 25, 2015 08:02 PM
IronFist
Sep 25, 2015 07:13 PM
chadds
Sep 9, 2015 05:26 AM
adamdrives
15
Aug 8, 2015 08:53 PM
