Rust issues?
Old Jul 12, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
Thumbs down Rust issues?
03 Civic EX coupe in Colorado
Some of the chips on the hood and front fenders rusted. Wiper arm chips rusted. Both rear fender lips where rocks could hit them have rusted.
Not deep rusting, but rather just surface rust. Friggin annoying. My non-7thgencivic that is a 1992, with a chip peppered hood, has ALOT less of the problem than the Civic.
Anyone else noticing the subpar corrosion protection on their 7thgen?
Old Jul 12, 2005
CraigW's Avatar
The only way I have found to prevent rust is touch-up paint the wounds soon after they happen.
Old Jul 12, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
You need to do something about that before it spreads, either that or get a new hood. It wont be easy but you can get it out.
Old Jul 14, 2005
Anywhere I found rust, I used some rust neutralizer on it. I have had great results using it on another car, with rust issues not returning so far.
The rear fender lips chips rusting might be an issue though. I am tempted to just coat the whole lip, and repeat as necessary.
Old Jul 18, 2005
Victorious's Avatar
Victorious will become famous soon enoughVictorious will become famous soon enough
what type of wet/dry sandpaper would u suggest using? fine? extra fine?
Old Jul 24, 2005
Victorious's Avatar
which type of sand paper?? coarse? fine? extra fine?
Old Jul 24, 2005
That will really depend on the amount of rust you look to remove. You want to use the least abrasive one to get the job done so that you dont over do it. Where on the car is the rust your removing?
Old Jul 24, 2005
White05EXSE's Avatar
White05EXSE is an unknown quantity at this point
...time for a carbonfiber hood and a body kit if you ask me.
Old Jul 24, 2005
paradoxblue's Avatar
my trunk. tip corner has a chip.. not sure where from. its rusting. had car less then a year. time to bitch
Old Jul 24, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
Yup, that's what I do. I have a nasty scrape on my hood. That's mean a CF Hood sometime down the road!
Old Jul 24, 2005
.....sounds like time for a carbonfiber trunk then.
Old Jul 25, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
isnt this ocvered by the rust proofing warrenty
Old Jul 25, 2005
yeah, but most people dont buy it.
Old Jul 25, 2005
Victorious's Avatar
its not covered if the rust comes from external damage or something
my rust is coming from the frame of the body on the edge of the tails
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
PierrePierre
Jun 17, 2015 06:22 PM
chirp the 1-2
Apr 19, 2015 02:19 PM
takadadojo
Apr 6, 2002 06:58 AM
astr033
Mar 12, 2002 08:30 PM
