ECU Fried 7th Gen cars have a Chronic issue - alternator bolts get loose and the loss of grounding will eventually fry the ECU
'01 Civic EX Issues - Need some help
Old Sep 23, 2006
2NR Werks's Avatar
2NR Werks is an unknown quantity at this point
#1 - Green key (immobilizer) is flashing, need this to stop.
#2 - Engine will not go past 3K
#3 - Surging idle, 800 to 1800, up and down , Idle air control valve needs cleaning??
#4 - Tach and speed-o stopped working??????
This all happened at the same time after a motor swap.
Need some advice - Thanks
Old Sep 24, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
you put something together wrong
Old Sep 24, 2006
youre not using the stock civic ecu i hope
Old Nov 21, 2006
ArNinetyEs's Avatar
ArNinetyEs is an unknown quantity at this point
Sounds familiar:
#1 immobilizer flashing, MIL on solid.
#2 Engine will not go past 1500.
#3 Starts to accelerate, dies, bucks, idles rough.
#4 Don't know about the speedo - but tach and temp gauges don't work at all.
I didn't put anything together wrong - it hasn't been apart. I was just driving it. It bucked hard, twice, then started this crap. It popped the alternator lock bolt and lost the alternator belt at the same time. Replaced them - but, of course, it didn't fix the real problem.
I have no answers yet. Came here looking for info. I'm going to pull the codes after I get off work tonight. I'll post any answers when I figure it out. My impression is: ECU related.
So far, I'm not very impressed with the reliability of this car. It is my first Honda (car - have had several Honda motorcycles). The alternator broke at 39k. Honda said, "Sorry. It is out of warranty. That'll be $580 to fix it."
Now at only 4 years old, it is giving symptoms of a crapped out ECU. I hope not...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
McD
Apr 29, 2015 03:50 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
civic_gt
Apr 19, 2015 08:15 AM
skywalker
Nov 8, 2001 05:04 PM
