Squeaking Noise From My Rear Springs
Old 11-14-2007
IrockCivics's Avatar
When I am driving, I can hear the rear springs squeak a lot. What could it be? The suspension I have on my car are H&R springs, with Koni Yellow Shocks. I bought the H&R's used, and the shocks were bought new. I have 195-55-15 tires, when I have people in my back seat, it is lowered more. Could they be weak or should I just replace them? Thanks.
Old 11-14-2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
Re: Squeaking Noise From My Rear Springs
i think is the camber kit.. springs doesnt make squeakin noise
Old 11-14-2007
greeen01civic4d's Avatar
^^^^ bingo, i had this problem a ways back, i can tell u how to fix it if u want, it does require a grease gun
Old 11-14-2007
and a grease gun needle, i fixed it on mine, and i can get u a needle if u want, they are like 4 bucks from cornwell, but it works great, did mine a month ago and still no squeaks, otherwise u have to buy a whole new rear camber kit
Old 11-15-2007
ok Imma have to check that out.... Can the car be driven like that? Will it cause any damage?
Old 11-16-2007
no damage, its just inserting grease into the bushings by way of needle, if u want to find out if that is ur problem, just spray the bushing with pb blaster, or other penetrating oil, if problem goes away, they problem solved.... get a needle and inject grease into the bushing, it works great, i havent had a single squeak since i did mine, hit me up on pm if u want to know more, i have pics an whatnot
Old 11-21-2007
kasimmmmm's Avatar
also lube your tie bar bushings...
it might not be your camber kit necessarily. tie bar bushings are more likely to squeek.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
ghondavic
Transmission
04-12-2017 09:37 PM
Foggy60
05-30-2015 03:51 PM
vtec_concept
05-24-2015 10:27 AM
oneheadlight
04-29-2015 11:30 PM
Quick Reply: Squeaking Noise From My Rear Springs
