camber kits
Old Jun 3, 2003
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
camber kits
when do you have to install a camber kit? when you lower your car or when you put new rims on yourcar because i was told to put a kit on when i got my rims but i heard different things from certain people so i just wanted to find out because my back wheels look like they are turning in from the top so if anyone can help me out.....
Old Jun 3, 2003
4bangin's Avatar
search, you should find all the answers. but anything like 1.5 and lower you may need atleast a rear camber kit. i have goldlines 1.75" all around and i have front and rear eibach camber kits and i am glad i got them. helps when you get the car aligned and whatnot.
Old Jun 3, 2003
BERGER's Avatar
but i don't have my car lowered at all. are sway bars the same as camber kits?
Old Jun 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
No theyre not the same. But if your car is not lowered you don't need them. Search and learn
Old Jun 3, 2003
bottlefed's Avatar
bottlefed is an unknown quantity at this point
when you lower your car, your allignment becomes way off and can't be alligned properly cause it gets aligned to stock specs. a camber kit sets your allignment straight. no you don't need one if you didn't lower your car but if you did and you drive alot, your tires will wear away on the inside and you won't know it untill they blow out
Old Jun 4, 2003
cdmx's Avatar
how much can an alignment at a shop adjust to?
Old Jun 4, 2003
Weaponx12o's Avatar
you mean the price? should be around 50-80 bucks
shouldnt this be in the suspension section?
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
