How much do alignment job cost you guys?
Old Jun 1, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Sup, all
I just got my alignment and camber kit installed today. Man it cost me supposely 200$ but my friend got me the wrong Front camber kit so i need to buy them from the store 35 buck and total cost me 247$ I have a question i have coil-over kit let says if i want to lower my car more or raise back highter do i need to realingment it and redo the camber? i kinda want to raise my rear little bit highter because it uneven.
Old Jun 1, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
If you change the height of your car again, I think you're technically suppose to get another alignment.
Old Jun 1, 2003
civicvtec1ps's Avatar
Search and Learn
ya if you change height or you car. then you will need to get realignment
Old Jun 1, 2003
sheizen's Avatar
sheizen is an unknown quantity at this point
firestone offers lifetime alignment it saves a lot of money
Old Jun 1, 2003
Voiceofid's Avatar
End Bringer
cost me 120 dollars at a local shop
i tried taking it to goodyear, and they said my car was too low, and they couldn't do it
Old Jun 1, 2003
so i can't raise the rear little higher? like a inch
Old Jun 1, 2003
666's Avatar
666
666 is an unknown quantity at this point
My alignment cost $54, they did a good job too.
Yes, when ever you alter the ride height of your car you are changing the camber, caster, toe in etc. When you raise the rear of your car up you will have to get an alignment again. Thats the only bad thing about-coil overs in my opinion.
Old Jun 1, 2003
dang
Old Jun 2, 2003
nguyen949's Avatar
nguyen949 is an unknown quantity at this point
firestone $120 for lifetime alignment great service and great job!
Old Jun 2, 2003
firestone do lower car? wow lifetime alignment that great do they do camber kit adjustment too?
Old Jun 2, 2003
sexcivic2k1's Avatar
give more info on firestone alignment, really interested!
Old Jun 3, 2003
nguyen949's Avatar
yeah my car is lowered on goldlines and i have spc camber kits..they adjust and do everything for mE! u guys mite want to call them and ask before purchasing the lifetime alignment tho..it mite be different down here..
Old Jun 3, 2003
CapYoda's Avatar
Escaped Convict
yeah check firestone/bridgestone locations...
they have decent deals... I might be heading there now to do lifetime alignment after I drop the car...
I got a computerized (aren't they all? heh) alignment at my local tire shop for $50. pretty cheap.
noticed the difference right away since my camber was off like 1.5 degree on the rear left since I got hit there and the shop that fix it never both to do an alignment or tell me about it.
doesn't the costco tire center have alignment too? whats the rate on those? usaully they have pretty competitive pricing on tires/install/lifetime warranty and services, etc.
I'm thinking of lowering car soon... and I dont really want to buy the camber kits but eh.. guess I have to. lol.
Old Jun 3, 2003
silverslug's Avatar
silverslug is an unknown quantity at this point
$80 at motorsport techniques in hayward,CA. Specialized in lowered cars.
Old Jun 3, 2003
Spider883's Avatar
9K Redline Owns U
70 bucks.. i actually just got one done today... i can only go to one place in town to get it done bc all the others i cant fit on bc my car is to low
Old Jun 3, 2003
Zzyzx's Avatar
Autocross Junky
$35 for a custom (Non-Factory) alignment. as in A little toe out on the front, 0 toe on the back, a litte extra camber on the nose, 1-2 Deg. Great for handling, not so good for tires. But I autcross, so my stickys are only on the car for race weekends, where my street rocks are on the rest of the time.
Autocross: Out here, we race with our Steering wheels.
Old Jun 3, 2003
reytito's Avatar
why can't garages accomodate lowered cars? is it the liftramp that won't clear?
Old Jun 4, 2003
Zzyzx's Avatar
Autocross Junky
it depends on how the shop has their alignment bench set up. If you have to drive up ramps then the are times where a car would be to low, and they dont want to be liable for any damange caused by driving up the ramps. others have the bench sunk in to the ground with a pit. in that instance, there are no ramps so any height vehicle could be aligned.
pheaton
May 4, 2015 08:26 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
wsking77
Aug 29, 2001 05:34 PM
