Official Suspension Drop Pictures Post
Old Sep 30, 2009
  #781
morphius88's Avatar
morphius88 is an unknown quantity at this point
Re: Official Suspension Drop Pictures Post
well tomorrow i will find out what the actual gap between the tire and bottom of the fender is, and i can go from there. If i need to get smaller tires, ill get em. which kit is better the one with the coil-overs or the separate ones?
gap is now about 3 fingers or so, probably an 1.5 inch gap. is that worth dropping? I dont want tires to rub
Old Oct 3, 2009
  #782
02Hondadx's Avatar
02Hondadx is an unknown quantity at this point
I well did a 2" drop using Skunk 2 lowering springs. Im getting ready to get camber kit put on. Later down the road, I want to re-do my drop and replace the springs with adjustable coil overs. Then that way i can get it lower. If you are wanting to drop it then id do it right the first time and get the adjustable coil overs and get front and rear camber kit. get it all done at once. then once its dropped go get a tuned alignment if you can, at a performance shop. It cost a little more than a regular alignment but its worth it. its more precise
Old Oct 4, 2009
  #783
Bloody Arro's Avatar
Bloody Arro is an unknown quantity at this point
Coilovers are a pretty rough ride.
Old May 9, 2010
  #784
popwar's Avatar
popwar is an unknown quantity at this point
new monroe struts in back
VENTUS 205/40/17 tires
1 1/2 coil drop in front . 2 coil drop in back
rubs on exit / entrance dips and sharp turns , might just need alignment ?
Old May 12, 2010
  #785
02_d17a1_dx's Avatar
02_d17a1_dx is an unknown quantity at this point
Lowered 1.5" : Tein S.Techs on stock struts.
On Maxxim "Fourteen" rims wrapped in 205/40 17 Nankang NS-1's
sorry for the crappy pics, havent had time to get good pictures or an alignment yet...
Name:	2010-04-01 13.06.02.jpg
ID:	78311   Click image for larger version
Name:	2010-05-02 22.25.32.jpg
Old May 14, 2010
  #786
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
megan racing full coilovers on 18's 215 x 35s, full drop
ID:	78314   Click image for larger version
ID:	78315   Click image for larger version
Old May 14, 2010
  #787
ronaldo9's Avatar
How do you like the megan's? Don't care about the drop but more of the ride.
Old May 16, 2010
  #788
dragin's Avatar
honestly not a fan of them or the company. had several issues with instal, ride quality on the front is ok, allot of bump steer and the rear is crap. used to have jic flta2's in it, those where much better ride quality. having jics rebuilt eventually... y i bought the megans
Old May 17, 2010
  #789
ronaldo9's Avatar
Thanks for the review, I keep blowing shocks and I'm not even slammed only about 1 inch drop lol. I need something that will survive the city roads and want something stiff in the rear. The tokico's were way too soft in the rear and I blew my koni's. Running out of options.
Old May 17, 2010
  #790
lordhelmet's Avatar
So if blues and konis are not working for you what do you plan on using? My rear tokicos (I agree they seem a bit soft too) seem to be blowing and I'll need to replace them at some point in the future.
Old May 17, 2010
  #791
ronaldo9's Avatar
My next option is either try the tokico ht's (d specs), bilsteins, or run a coilover and keep the back a little bit higher. The konis were great while they lasted but I'm not a fan of their design in the rear having that ring. I have hit potholes so hard on the belt parkway its actually stripped that c ring from the housing.
Old May 17, 2010
  #792
i agree the tokico hp is a bit soft in the rear, but at least its not sagging or blowing like oems. and im going on 3 yrs of use on terrible roads. its just a small shock back there so you cant expect much. next time go with bilstein, they should be stiff enough for you.
Old Jun 23, 2010
  #793
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Skunk2 lowering springs 1.75" and stock struts... Never had a problem with the OE's blowing, and Im going on 2 years now.
Old Jul 25, 2010
  #794
Replaced my S.Techs with Option Racing Coilover sleeves, because Im getting full coilovers soon, and decided to blow my stock shocks and go low and have some fun. Rear is beyond maxed out (removed one adjuster) and the front is halfway, could go ridiculously low in the front, but not going to, due to ground clearance issues.
Comment/Questions welcome
Old Jul 26, 2010
  #795
2002civ's Avatar
2002civ is an unknown quantity at this point
17inch rim, tien super sport full coilovers with spc camber kit
Old Jul 26, 2010
  #796
pon55's Avatar
^ ^ ^ ^ Very nice clean look.
Old Jul 27, 2010
  #797
2002civ's Avatar
thanks..i do my best to keep it clean, not always easy lol
Old Aug 1, 2010
  #798
Miyagi's Avatar
Miyagi is an unknown quantity at this point
Old Aug 1, 2010
  #799
Miyagi's Avatar
Setup -
GC front's
Skunk2 rear springs
tokico dspec all around
tanabe front upper strut bar
tein rear upper strut bar
skunk2 rear camber kit
rsx 19mm lower rear sway bar
Old Aug 4, 2010
  #800
Black Magic's Avatar
Black Magic is an unknown quantity at this point
Tein SS-P Coilovers...
Old Aug 4, 2010
  #801
Speed9117's Avatar
Speed9117 will become famous soon enough
Setup
Eibach Sportline springs (1.4/5" drop)
Tokico HP (blue) shocks/struts
SPC rear camber kit
215/45/17 tires
before
and after
This setup gave me noticeable handling gains on those fun windy back roads with a surprisingly good ride. It's a little stiff, but not harsh.
Old Aug 4, 2010
  #802
pon55's Avatar
Time to go lower.
Old Aug 4, 2010
  #803
Speed9117's Avatar
haha I wish. I'll have to live with this for now though, I don't have enough money to go lower.
Old Aug 18, 2010
  #804
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
ep3 raceland coilovers
ID:	79047   Click image for larger version
Old Aug 24, 2010
  #805
IMSHANE's Avatar
IMSHANE will become famous soon enough
I have Tanabe DF210's with Tokico DSpec adjustable struts.
Pictures are Before After and Comparison.
Name:	New Camera 006.jpg
ID:	79139   Click image for larger version
Name:	2010-08-19 15.31.08.jpg
ID:	79140   Click image for larger version
Old Nov 2, 2010
  #806
sam68's Avatar
sam68 is an unknown quantity at this point
02 coupe
Eibach Sportlines 1.4" drop (settled a little more like 1.7")
Tokico D-Spec's
205/45/17's
Old Nov 2, 2010
  #807
pon55's Avatar
Just raised it up for winter.
Raceland coilovers,Rota torques w/ 205/40/16.
Old Nov 4, 2010
  #808
very nice i like the new rims and heads
Old Nov 4, 2010
  #809
Originally Posted by sam68
02 coupe
Tokico D-Spec's
205/45/17's
is that hid retrofit i spy in the headlights?
Old May 11, 2011
  #810
hondafan03's Avatar
hondafan03 can only hope to improve
here are some pics of my em2 on nex one peice suspension with two different sets of wheels two pics i have
dr 16s and the other two pics i have sportmaxx 002s
[ATTACH]80817
[ATTACH]80818
[ATTACH]80819
[ATTACH]80820
ID:	80817   Click image for larger version
ID:	80818   Click image for larger version
ID:	80819   Click image for larger version
