Tie Rod End installation...?
Old Apr 21, 2003
RSDCivic's Avatar
RSDCivic will become famous soon enough
I just recently installed some new springs, but in the process I screwed up the bolt on the tie rod end. Does anyone know how the hell to get the tie rod end off of the tie rod to install the new piece?
Old Apr 21, 2003
Mbow's Avatar
Yes, see that nut just behind the tierod end. You need to loosen that nut or hold it while loosening the end itself.
The nut and the end bolt up against each other.
The best way to do it is this:
Leave the tierod end throught the strut and bolted into place. Then, use a wrench to loosen that nut that butts of against the end. It is pretty tight so yoy may want to spray some wd-40 on to the threads.
Old Apr 21, 2003
RSDCivic's Avatar
Thanks for the reply
Old Apr 21, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
after that you'll need an alignment, might just be better off taking it to a shop in the first place
Old Apr 22, 2003
RSDCivic's Avatar
all it needed was a little love from the impact driver hah, but thanks for the posts, its time to go get an alignment...
Sep 26, 2023 06:44 PM
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alwaysloyal360
Jul 29, 2015 02:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
17
Jul 23, 2015 11:48 PM
