squeeky rear teins
Old Apr 12, 2003
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
Unhappy squeeky rear teins
both sides of my rear tein ss squeak really bad. and its so annoying. im thinkin that greasin it up will get rid of it, but are there any other thing(s) i could check for?
Old Apr 12, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
did you get any camber kit ?
Old Apr 12, 2003
xHoteKx's Avatar
Tomotor
yea i got the SPC camber kit in the rear.. my fronts didnt need to be adjusted
Old Apr 12, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
What suspension components are you running with? Sounds like you are using uretahne bushings somewhere if it's squeekin
Old Apr 13, 2003
xHoteKx's Avatar
Tomotor
suspension components? like in strut bars? if so, none. i took off my front and rear upper strut bars when we installed the teins.. so i only have my tein ss and the rear spc camber kit installed
Old Apr 13, 2003
artychris's Avatar
artychris is an unknown quantity at this point
So it finally happened to ya huh?
I patched mine up.
1. Front: Get lightweight wheels...
The front springs shift a little bit less since I got the Slipstreams put on. Less weight = less resistance = less strain on springs.
2. Rear: Lightweight Wheels, Upper Rear Bar, and a full tank of gas.
The rears still squeek like a *****. The Slipstreams helped lessen it but it'll still come up.
My rear squeaks when I'm low on gas... the gas tank helps pre-load the springs. I also put my gym bag and school bag to weight it down.
The Rear Upper will prevent the rear from moving independently.
Old Apr 13, 2003
xHoteKx's Avatar
Tomotor
hm ok, then i'll reinstall my rear upper strut bars.. i should probably put my back seats in just for the added weight..
Old Apr 14, 2003
artychris's Avatar
the patch!
The problem isn't completely solved... it's just a patch
If you find the solution, post.
Old Apr 14, 2003
xHoteKx's Avatar
Tomotor
i raised the rear up a lil, and the squeaking went down a whole lot.. barely even squeaks now. oh, and i put my rear upper strut bar on too. that might help.
for reference, my rear is a lil bit more than 1 finger gap.. maybe like 1.25
Old Apr 14, 2003
eXNBP's Avatar
BTw when is it squeekin? Going over speedbumps or something?
Old Apr 15, 2003
xHoteKx's Avatar
Tomotor
when i open/close my door, sit in my car, goin over small cracks on the road.. pretty much whenever the back bounces just a lil bit. i can push down on the trunk and it'll start squeaking
Old Apr 15, 2003
B390LU's Avatar
B390LU is an unknown quantity at this point
Hi all, I have a full coilover with a brandname u guys might not have heard of. BTW, I'm in Australia and I had the same problem with u guys before. What the suspension shop did was check whether I had part no 12 in this link and they also took out the dust boot cover since it kept getting wedged in between the springs coil. Taking the dust boot cover should be no problem for me since it doesn't snow here but can be a problem to u guys.
The noises are gone till now and everything's perfect. The shop that did the repair is the main distributor for my full coilover kit so I reckon they really know what they're doing.
Hope this helps
Old Apr 15, 2003
xHoteKx's Avatar
Tomotor
poo.. michigan is famous for its random snow storms (like the one we had last week....) but i know for a fact that i have that part number 12 in. when i took out the rear struts out yesterday, i checked for all the parts.
btw, what kind of full coilovers do you have B390LU?
Old Apr 15, 2003
B390LU's Avatar
click here. Mine looks almost similar as the B+G except that I don't have helper spring.
Old Apr 16, 2003
RedDragon333's Avatar
Ive had mine on for a little while and no problems, i hope i dont have to deal with the same thing
Old Apr 21, 2003
xHoteKx's Avatar
Tomotor
man, the squeeks are back.. i have no clue what it is now.. should i lube something? if so, what and what should i use?
Old Apr 21, 2003
B390LU's Avatar
why don't u bring the car to the shop that installed it?If the kit turns out to be faulty then they should do something about it.
Old Apr 21, 2003
xHoteKx's Avatar
Tomotor
i installed it with a friend
Old Apr 21, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Tein
Email them!!!
sales@tein.com
Old Apr 29, 2003
Eeep I've been infected by squeeky rears~~ I emailed them.
Old Apr 29, 2003
artychris's Avatar
I haven't had a single squeak in the rear since I installed my RS Akimoto floor bar. I got my gas down to E and it still doesn't squeak!!! Before I had the bar on, my rears squeaked so bad especially when the gas gets low and the rear is not as preloaded. I put on my Slipstreams and it helped out and squeaked about 15-20% less. Since I now have the floor bar, it stopped all the squeaking. But the ride quality is much harsher overall.
Old Apr 29, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
to me it sounds like it's your camber kit that is squeaking. If the bushings on the camber kit are polyuretahne - that might be the problem. You'll need to lube them... it should have told you what to use on the instructions on how to install the camber arms. The stock camber arms used rubber bushings. There shouldn't have been any noise with these. I hope I've helped you out.
Old Apr 29, 2003
xHoteKx's Avatar
Tomotor
Re: Tein
Originally posted by sovereign82
Email them!!!
sales@tein.com
man i emailed them like 3 or 4 days ago.. and still with no reply
Old Apr 29, 2003
I dont think its the camber as I have an SPC camber...and it seems only the Teins suffer for the dreadful rear sqeeeeek syndrome.
Arty, thats a nice bar but a little difficult to get...whats a comperable bar to that one here in the US.
Matt
Old May 2, 2003
artychris's Avatar
Matt
Difficult is right. I bought it off of 3rdCivic, but he doesn't seem to post as much on the board anymore.
The RS bar is freakin' amazing. But what sucks is that it makes the ride so much harsher. The Teins used to absorb bumps like stock, but now my car feels like I'm riding on a 2.5" drop with 18s when I actually have a 2" drop with 16s! It eliminated the rear squeaking 100%. It's been over a month since I had my rears squeak.
DO NOT GET THE AROSPEED GENERIC FLOORBAR!!! It's not as good.
Old May 2, 2003
So what bar would you recommend? I absolute HATE the squeeking and if I can't fix it.... /auction Tein SS
Matt
Old May 2, 2003
artychris's Avatar
Matt, get the RS Akimoto bar. Man, I'm a believer after it stopped the squeaking! My friend has a 95 GSR with H&R Sports + Tokico Blues and he says that the ride in the TEINS feels like a pillow compared to his setup. Since I got the bar, he says that my ride feels a lot like his when he adjusts the damping for autocross. All I need now is the get the Neuspeed Upper Rear bar for the trunk to stiffen up the rear a bit more... I'm going to have to soften my suspension for street use because it's just waaaay too harsh on Seattle streets. But I'd rather have my back hurt than to hear what sounds like a dozen animals in my trunk trying to claw their way out.
Summit Racing has it for $250.
Old May 2, 2003
Umph...I'm going to talk to Tein...I like my pillow ride lol
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
czarlun
Sep 14, 2015 08:16 PM
Josh 1973
Sep 7, 2015 10:10 AM
