Camber Kit????
Author created thread, but forgot to type something.
or, it was a double post . Like clicking twice on submit or something.
Get an alignment to see how much adjustments you need first then consider if getting a camber kit will help save your tiers. That is the best way I can explain it. ALl cars are different and should be tended to different needs.
Usually anything above 1.25" does not need a camber kit though it is recommended that you get a camber kit if you lower at all. It will save your tires. YOu will probably only need the rear, but might as well spend the extra $20 and get the front too, it will help with the alignment. If you do lower, you should get an alignment some time thereafter.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Hutch1051
Sep 29, 2015 09:20 AM
