Can I correct the camber myself??
Old Mar 21, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
Okay, I have a deal through Tire Discounters where they rotate and balance my tires for free, plus I get a free alignment. Well, since I dropped my car and it has a body kit, they cannot get the car on the hoist. So I was wondering if anyone has corrected their camber themselves and how I can tell when it's back to zero degrees. Could I just use a level against the wheel?
The reason I ask is because It'll cost me $70+ to align my car. I'm just looking to save some money.
Old Mar 21, 2003
robbclark1's Avatar
Retired suspension supermod.
I would get the alignment just to be on the safe side. $70 to protect your cars chassis and tires, y not? There are stock camber adjusters but they don't have the range of aftermarket ones. You really don't want your rear camber to be completely at zero. it should have a slight negative camber to help handling. You could adjust yourself and "eyeball" it but I wouldn't trust that both sides would be equal unless you have the machines for it. Just my .02 cents
Old Mar 21, 2003
flotsamm's Avatar
To add to the above, if you adjust it yourself most likely you'll need to have the toe and caster checked also which require an alignement rack to do it right I believe. Maybe check around and see if you have another shop that can accomodate your body kit and get you up on a rack..
Old Mar 21, 2003
brents1's Avatar
yeah, you're right. I'll look around today for different shops that can do it. thanks.
Old Mar 21, 2003
robbclark1's Avatar
The place i go to has one where you drive up on to the top, they lift the car in the air, and attach these big disks to your wheels. then there is this big machine that bounces light off those disks and give the mechanic a digital display of the camber, the toe, etc, all of it. It is quite high tech. Look for a place that has something like that.
Old Mar 21, 2003
brents1's Avatar
okay. thanks. I'll have to look for that.
Old Mar 22, 2003
Elite's Avatar
Elite is an unknown quantity at this point
WTF aliens and ish or what that ish scares me
Old Mar 24, 2003
vincenzobar's Avatar
THE WOP
vincenzobar is an unknown quantity at this point
Dude. I had a kit and am lowered 2 inches-ish with gold lines. All the jack assess need are some wood planks to get the car on at a less steep angle. Hell sears did mine.
BTW they have no idea what a SPC Camber kit was and tried to charge me 175 for the alignment. Idiots. Took them nearly 3 hrs. and i got it almost perfect with a level in .5 hrs. when i put the SPCs on.
I found Pepboys where i live are the know it alls. Definetly find a shop that knows what they are doing if you have Aftermarket cambers.
Old Mar 24, 2003
brents1's Avatar
yeah, that's what I was wondering... why can't they just use some planks to drive up on so you can get a jack under the car? I need to see if they'll do that.
Old Mar 25, 2003
cdmx's Avatar
Thats what ill be doing!!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
