Tanabe Springs Install
Old Feb 17, 2003
LiKEaFeRiO's Avatar
Anyone have installation instructions for the Tanabe Springs?
I just got mine in the mail and everything is in Japanese.
I was looking through some other threads about springs and it called for cutting the bumpstop and such.
The springs came with new bumpstops and 2 plastic cylinder shaped pieces that look that hey would fit in the strut.
Im broke and Im lost.[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Can anyone help me?
Old Feb 18, 2003
LiKEaFeRiO's Avatar
Anyone care to help??[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Feb 18, 2003
VNlilMAN's Avatar
The Standard One
theres a couple DIYs found up in the DIY section(gc, koni, springs same installation process)
also follow my detailed spring install found up at the top of the suspension forum.
instead of cutting your bumpstop, just replace it with the one provided. also the tube is called a spring isolator. you put it on the bottom part of the front springs. it should seperate the spring from the bottom perch to prevent any rattling noise...
if you want i'll be down to help out cause i'm not too far from glendale. i wont do it for you but ya i'll help out.
Old Feb 18, 2003
LiKEaFeRiO's Avatar
Thanks alot.
I won't be able to do it until next weekend because of work and Im not even sure if I want to put it on.
The springs are made for all 2001+ civics. Will the rear of my sedan be lower than the fronts?
I have a sub box in the trunk so the rear is already lowered a little.
Any suggestions on other springs? Im think of selling these for something else.
I don't have a spring compressor and found this ghetto way. Any better ways?
Old Feb 18, 2003
VNlilMAN's Avatar
The Standard One
oh you have a sedan.. a member here had those springs on a sedan and he wasnt too happy with them. i think his sn was something like piccolob.... something like that... only springs i recommend on a sedan are neuspeed sports for sedan. i got them for $140 at a shop in eagle rock.
as for that method, you probably wont even have to do it that way. i've heard our springs were so soft, you could just have someone put their weight on it to compress it. when i was trying to do the spring install, it seemed like i could too(only problem being, i was doing it myself). so ya i tried using the spring compresser from autozone(its free to rent) but found it a bitch to use..
Old Feb 18, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
make sure u post some pic at the mem's ride, i wanna see how they look
Old Feb 19, 2003
LiKEaFeRiO's Avatar
Thanks for your help guys but I've decided to sell them.
I cant take the risk of rubbing or blowing anything. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
If some locals don't take it I'll post it up on the marketplace.
Old Feb 19, 2003
VNlilMAN's Avatar
The Standard One
get neuspeed sports..
if you want you can ride in my car and see how its like..
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
