Hydros on a 2002 (pics)
Old Nov 26, 2002
alex053's Avatar
Hydros on a 2002
My friend just put hydraulics on his girlfriends car and Im next. when the tax return comes in its going on for sure.
Jennifers Civic on Hydros
Old Nov 26, 2002
VNlilMAN's Avatar
The Standard One
daaaamn that **** looks f**kin phat.. she could lay the front too... something bags cant do yet.. do you know how much the setup was?
Old Nov 26, 2002
alex053's Avatar
i talked to my friend about laying harder in the front. he said it hits the steering so i will have to look at this weekend when i go over there. Not sure how much it was but you can find decent 2/4 sets for under $1000 then accumulators, batteries, 90 degree fittings to fit under the hood. You will be under but very close to 2 grand.
Old Nov 26, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
damn man thats awesome. how many switches is it hooked up to and what can it do?
Old Nov 26, 2002
alex053's Avatar
a 2/4 can do front, back side to side. with 5 switches probly. I havent seen it in person but the 4 dumps gives you control over the wheels and the 5th swich to work the pumps. Im new to this so if im wrong somebody help. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 26, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
Now install some rear camber kits, and it would look nice.
Old Nov 27, 2002
alex053's Avatar
No reason for the camber kit. Just lift it back to stock height and drive away. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 27, 2002
VNlilMAN's Avatar
The Standard One
eh, i agree with 010010010010
i'm sure she doesnt drive it stock height all the time. maybe set the camber when you drop it 2" or however low she normally drives... so when she slams it, the wheels wont be as tilted... man they should have some sort of self adjusting camber kits for this reason
wait nm.. it wouldn't work anyways cause you would have problems with it rubbing since the tires wouldnt tuck...
Old Nov 27, 2002
Rider's Avatar
Rider is an unknown quantity at this point
Hey...that'S really crazyyy!!
So ... how much???
Thanks!
Eric
Old Nov 27, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
$%#&*%#!)(&%!( AWESOME!!!!
Now i want bags on my ride... =|
Old Nov 27, 2002
alex053's Avatar
It depends on how much the install is, how many batteries you run and what kit you go with. Pro Hopper is the best, CCE also makes a good kit. If you go with hydros spend the money on accumulators...it will ride like a caddy with them.
Old Nov 27, 2002
alex053's Avatar
Quote
[hr] Posted by AK
Now i want bags on my ride... =| [hr]
this car is on hydros, a little different than air but same prinicple.
Old Nov 27, 2002
Rider's Avatar
Ok....like everything it depend on the quality you want....
But just wondering about aprox prices...for a normal setting...not side to side...just front back with accumulator ( why not....do it great or dont do it... ) A great setup without being the best...to have the look with a smotther ride....!
Eric
Old Nov 27, 2002
VNlilMAN's Avatar
The Standard One
its slightly cheaper then air...
in the 1000-2000 range.
i would say air is around 1500-2500
Old Nov 27, 2002
Rider's Avatar
What is the difference for someone like me that don't know about hydro and air suspension??? I know that it is air and oil...but in the installation....in the maintenance.....they do the same job at the end no?
Eric
Old Nov 27, 2002
VNlilMAN's Avatar
The Standard One
parts
air: compresser, tank, valves, bag/cylinder that replaces both shock and spring(well for our cars)
dro: batteries, pumps/dumps, cylinders and springs, cylinders replace shock internals. from my understanding, you trim the springs, use the cylinders as a top perch to raise/lower the car.
maintence, i would think air is a little bit easier to maintain. cause its just air. compressers fill up the tanks with air. dro, you have not one but a couple batteries in the trunk. i dunno air just seems safer and more simple.
end result.. they both have their good and bad.
it's easier to hop, do "tricks" with dro.
air is mainly just for lower/raising.
i've heard the ride with air is better then dro.
i dont know too much about hydraulics so i'm sure alex could tell you more then i.
Old Nov 29, 2002
alex053's Avatar
With juice you need to charge your batteries about every two weeks. this will vary by how much you play with them and the batts you have. You will also change the seals in the stroke about every 6 months. I have been in bagged trucks and juice cars and the ride was about the same. I like hydros because you get more lift, its faster, it doesnt run out, and its cheaper. for more info check out :
Lay it Low
or
Pro Hopper
i learned alot from these sites and my friend Codey. I am new to this also so if you learn something new please post.
Old Nov 29, 2002
dru106's Avatar
ThE CoRRupToR
how much will it cost if i put air bags only on front wheels?
Old Nov 29, 2002
VNlilMAN's Avatar
The Standard One
only on the front? haha thats ghetto... it depends on the setup.. cheapest would be like 700 but then you could only raise/lower really slow, no preset switches, just a manual one. so you have to hold the button down till your desire height..
most expensive could be like 1500. but i would say a nice decent setup would run 1100.
Old Nov 29, 2002
Rider's Avatar
Hey those 2 sites are really interesting..thanks to share!!!!
Eric
Old Dec 2, 2002
alex053's Avatar
Well I worked a deal for some hydros but i need accumulators. I need to get those quick or it will ride like butt. im off to check ebay. I should have at least the front done by monday. one pump 5 dumps. later i will get 3 more dumps for more control.
mac25
Aug 21, 2015 11:14 PM
4jacks
Aug 17, 2015 01:26 PM
Snax
Aug 12, 2015 10:23 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
manfredww1
Jul 14, 2015 10:24 AM
