rubber stopped..
End Bringer
rubber stopped..
a friend of mine installed 2inch drop intrax springs on my friend's 2k1, when he installed it, he shaved half of the rubber stop off from the shocks, and he said that the shocks won't blow that way, and my friend is still riding on his stock shocks, after 2 months. is it true?
Escaped Convict
yeah. it'll help.
duno why though. lol. and I'm not too sure how much you should really cut.. I guess it depends on the drop and spring and etc.
but I think in Goldline and Neuspeed's instruction, they recommend cutting it to a specific amount...
I'm sure someone will give you a more definite answer soon..
End Bringer
well, he said that won't cause it to bottom out, i was planning to get koni struts too, but if that trick can prevent them from blowing, then i am all game
The Standard One
i know it prevents from bottoming out cause you get more shock travel but i dont think you have a less chance of blowing the shocks. i'm pretty sure you have even a greater risk since the shock is going to travel more, causing more stress on the shock.
and reason why toolows civic blew so quick is probably due to the ride height being very low and just that its coilovers and they tend to have a higher spring rate, putting more stress on the shocks compared to springs.
dlg1985
Jul 23, 2017 10:03 PM
Sep 27, 2015 11:33 AM
Laucard
Sep 18, 2015 07:11 AM
Klame9420
Sep 7, 2015 10:03 PM
DerbyDad03
Jul 27, 2015 11:34 AM
