How Low Should I Go?
Old Jul 15, 2021
LilDongWater's Avatar
LilDongWater is an unknown quantity at this point
I have a 2004 LX I’m looking to lower it I found some really nice coil overs that are adjustable. I wanna lower it so I doesn’t look stock but I don’t want to have to angle every time I go over a speed bump or bottom out coming out of my driveway.
Old Jul 15, 2021
FRSam's Avatar
Click Here
Re: How Low Should I Go?
Define "really nice".
Assuming you have an "average" driveway (meaning it has a small dip at the end), you should have no issues dropping it about 1.5". Any more and you run the risk of scraping. Mind you, I scraped leaving my driveway on stock ride height so it's a tough question to answer. Calgary roads suck too so that doesn't help lol
Old Jul 15, 2021
How much do you wanna spend?
Also, like chez said, depends on the roads, speedbumps, and driveways you encounter. Chez scraped at stock, meanwhile I lowered my 2002 by about 2.5" and only scraped on stupid harsh speedbumps that SUVs would be weary of
Old Jul 15, 2021
The brand is TruHart it’s their street performance coil overs. If you have some other brands I’m al ears. I was thinking around 1.5 inch drop.
Old Jul 15, 2021
FRSam's Avatar
Click Here
TruHart is about as cheap as you can get. I’d save a couple hundred bucks and get Teins. Riceboy had them on his civic so he’s better to talk to than me.
Old Jul 15, 2021
Had Tein Super Streets for... 13 years? Dropped $1250 on them back in 2004 and they lasted the life of the car. That $1250 was a steal back then, since the SS-P (super street with pillowball mounts, which is what I got) retailed for $1500+. Now, if you don't need adjustable dampening like the Street Advance (which replaced the Super Street line), the Street Basis run about the same price as the truharts you're looking at, maybe a bit cheaper. No matter what you get, make sure they're made for the 03-05 civics. Honda upped the crash bolt size from 14mm to 16mm after 2002.
Evasive has them for $560 shipped
If you want adjustable dampening, Evasive has them for $648 shipped
Looks like they don't make the pillowball upper mounts with fancy camber plates anymore, but if you can find some, I'd recommend them. They retailed for like $200 and they replace the entire top hat. Otherwise, use your OEM top hats
edit: case in point, I found the coilovers I had: https://www.corsportusa.com/i-19855-...er-mounts.html
Old Jul 15, 2021
truehart... save for better ones
saves money in the long term
Old Jul 15, 2021
Thanks for all the advise guys it really helped me out a lot. I’m sure I’ll be posting again soon about exhaust recommendations.
Old Jul 16, 2021
BrotatoChip's Avatar
Super Moderator
I put Tein Street Advance Z coilovers on my Civic about a year ago (thank you stimulus check). Set it for the recommended setting which was around a 1.7" drop I think. It was actually a slight lift from the Eibach lowering springs I had before. No complaints from me so far.
civic05acer
May 1, 2006 02:16 PM
drew22mader
Jun 9, 2005 06:31 PM
dru106
31
Oct 8, 2003 09:12 AM
mrad55
21
Apr 10, 2003 10:07 AM
ironcow
19
Jun 13, 2002 03:00 AM
