bumpy ride spring recommendations or go back to stock?
Old Feb 28, 2014
hunnyjb's Avatar
hunnyjb is an unknown quantity at this point
when i first purchased my 02 civic in back in 05 i lowered it right away with neuspeed sport springs. It wasn't until several years later, i would say about 2010 i started to notice that my ride had gotten a lot bumpier. I could feel every little bump on the road. I came to these forums and after reading and asking around i decided to replace my stock shocks with tokico blues hopefully to get a much smoother ride, but unfortunately there was very little improvement.
I tried to just tough it out until my next vehicle purchase but my car still runs really good so that may not be awhile, but i've really got to do something about the bumpy ride. I have a few things i'm thinking about doing, and id appreciate the input from these forums again.
a.) go back to OEM springs:
I'm not sure if i'm able to use stock springs on tokico blues though?
if i go this route, should i be wary of this deal below?
http://www.ebay.com/itm/131065438490...84.m1423.l2649
b.) try a different pair of lowering springs:
if i cant get stock springs back on because i now have tokico blues, id appreciate some suggestions of another pair of aftermarket springs i can try. lowering height is not a concern, my only priority is to get a much less bumpy ride.
c.) go back to stock springs/shocks:
this is what my local mechanic recommended that i should do, but if i can go OEM on tokico blues then wouldn't that equal a more comfy ride than with stock shocks? He told me he wasn't sure if he could get OEM springs back on an aftermarket shock though. If i go this route, is the link below a good deal?
http://www.ebay.com/itm/371014191016...84.m1423.l2649
d.) Coilovers:
i really only want to do this if it will actually be a smoother ride than oem springs/shocks combo, and if it is possible, what would be the top 3 options (if money is not a worry)
help!
Old Feb 28, 2014
Poopies's Avatar
Super Moderator
Re: bumpy ride spring recommendations or go back to stock?
A.) Yes, the Blues are considered to be close to OEM spec and will work with stock springs. Make sure you get the precise year though. That link is for 8th gen, you should look for something in your year.
B.) You might want to look for something that'll raise it a bit. The lower your car gets, the bumpier the ride. Generally speaking, that is.
C.) I don't see brand or anything on that link. I wouldn't trust it as OEM.
D.) Nope, coilovers generally sacrifice comfort for performance and adjustability.
There are a lot of threads on here covering every question you asked. Just use the search button!
Old Mar 1, 2014
hunnyjb's Avatar
i cant seem to find OEM on ebay...but i did find a brand called moog?
http://www.ebay.com/itm/Moog-81476-F...30c565&vxp=mtr
any advice?
also, if i go with option A, will the tokico shocks make the ride smoother than OEM shocks? sorry as you can tell i have no idea how this works
Old Mar 1, 2014
GolNat's Avatar
Prelude Owner
Moog is a good company. Tokico shocks are going to be a little firmer then stock since they are more performance oriented. KYB will be more stock like.
Old Mar 1, 2014
hunnyjb's Avatar
im sorry when you say they will be more firmer do you mean the ride will be less bumpy or more than stock?
Old Mar 1, 2014
Poopies's Avatar
Super Moderator
GolNat means bumpier. The firmer and more "performance oriented" a shock is, the rougher the ride.
Old Mar 1, 2014
bumpier as in "thud" or bumpier as in "boingo, boingo"?
the firmer a shock is, the less it allows the spring to move. good for stiffer springs, such as eibach. so it will "thud" more on bumps, but won't go "boingo, boingo" around with the softer OE shocks (which are paired to softer springs, so should not be an issue, except it will roll a lot more in corners).
sorry, this was the least complicated way to explain i found.
Old Mar 1, 2014
bravo79's Avatar
bravo79 is an unknown quantity at this point
Stay away from KYBs they are stiff as sh***T i had them and I was complaining about how bad the ride was just like you. Tokico with OEM spring going to be stiff too the best combo for comfort for me was tien h tech with Tokico Blues but still stiff in my opinion specially in the cold (winter) the best option for comfortable ride would be Honda OEM springs and shocks.
Old Mar 1, 2014
GolNat's Avatar
Prelude Owner
KYB are suppose to be OE equivalent. Showa is OEM.
Old Mar 3, 2014
hunnyjb's Avatar
hey guys i appreciate all the input. to be more specific, yes im looking to make my ride not go THUD! everytime i hit a bump or go over a speed bump or i drive over a groove in the road it feels like my car is going to crack in half.
when i was lookin at the spring list on this site i noticed that the eibach prokit is only a 1 inch drop. Since going OEM springs will still not be a great match since i have tokico blues on, how do you think the eibach pro kit would work out?
Old Mar 3, 2014
Mine still does thud more than stock... I have them.
Old Mar 3, 2014
rustycivic's Avatar
rustycivic is on a distinguished road
Pro-kit will be better matched to the Tokicos than the stock springs
Old Mar 3, 2014
There's that too, thanks, rusty.
Poopies
Apr 20, 2017 11:36 PM
0$1R1$
May 9, 2015 03:48 PM
oneheadlight
Apr 29, 2015 11:30 PM
GH04si
Apr 15, 2015 08:13 PM
