Suspension overhaul
Old Dec 26, 2012
7thgensurvivor's Avatar
7thgensurvivor is an unknown quantity at this point
Suspension overhaul
New to the forum and relatively new to my civic.
Inherited a 7th gen 2002 civic ex with 200K+ miles. Suspension needs some work.
There are some great write ups here, so thanks for all the time you all have invested.
I plan to do the following:
- LCA bushing replacement
- Sway bar bushing replacement
- ball joint replacement
- stabilizer bar end link replacement
I saw good write ups for all of the above, just wondering if there is anything I should keep in mind when doing all three, in terms of order. For example, leaving the LCA attached to assist in breaking the ball joint loose. I am sure I will start to figure things out as I get under there, but if you have any tips to save me from running in to trouble, I would appreciate it.
Thanks,
-- Pete
Old Dec 26, 2012
Re: Suspension overhaul
Oh, and if there is anything else I should check or think about replacing while I am in there, please let me know.
Thanks!
Old Dec 27, 2012
sl33pyriceboi's Avatar
are you planning to keep stock suspension? like stock springs/sturts?
Old Dec 27, 2012
front top hat ball bearings?
are the shocks good?
Old Dec 31, 2012
Yes, planning to keep stock suspension. Not sure how to tell if the springs, struts, shocks or top hat ball bearings need replacing.
-- Pete
Old Dec 31, 2012
lowlife9's Avatar
unless there physically damaged or making noise i would go by age and or mileage. there fairly inexpensive so you mite as well replace them while everything is apart. you wouldn't want to have to go back and replace them a month later then have to pay for another alignment.
Old Jan 1, 2013
keep the springs. shocks *might* need replacing
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
